Tires help
Old Mar 23, 2014 | 03:17 PM
PPBman's Avatar
PPBman
Default Tires help
Changed the oil today after the long winter sleep, added air to the tires but two valves would not take air. Values could release air but not take air. TPMS problems perhaps. Saw a bit of looked like grey rubber around on of the valves that would not take air.
Any thoughts on what the problem could be?
Appreciate any help.
Old Mar 23, 2014 | 05:35 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
If the valve stems "released" air, but wouldn't allow you to inflate, I'd check the air chuck you're trying to inflate with.
Old Mar 24, 2014 | 03:54 PM
strand rider's Avatar
strand rider
Only thing that can possibly be checked is the valve stem, if the problem is in the valve. UNscrew and check for damage. Hard to figure.
To Tires help
