Need help with linelock Install
Old Mar 25, 2014 | 07:16 PM
plumberh2o's Avatar
plumberh2o
Default Need help with linelock Install
I am ready to Install my line lock, but I need some Info? On the master cylinder witch line is the front breaks the front line or the rear line?
If you have done this to your car what is the easiest place to run the wires through the fire wall?
Thanks KenCan
Old Mar 26, 2014 | 12:49 PM
FederalPerformance's Avatar
0FederalPerformance
Former Vendor
put the connections close to the abs module, the lines are labelled on the unit.
