oil pressure problems
Old Apr 1, 2014 | 02:37 PM
savageone's Avatar
savageone
Cruising
Default oil pressure problems
I have a 99 with 127,000 miles,none abusive driving ,on my way home this particular day,my oil pressure suddenly drop to zero,stopped pulled over to the side of the road to listen for a rattle.none heard,continued to proceed toward home about 40 miles,still no rattling or other noises,oil pressure still at zero.the next day I went out to see if I could diagnois the problem,crank the car up.oil pressure goes up maxed out then drops to zero,still no noise,changed oil pump,timing chain and gears,and sending unit ,oil pressure still at zero.help me please:
Old Apr 1, 2014 | 02:45 PM
3boystoys's Avatar
3boystoys
Oil pressure sensor most likely, THOUSANDS of posts on the subject.
Old Apr 1, 2014 | 03:00 PM
savageone's Avatar
savageone
Cruising
oil pressure unit sending has been changed also.
Old Apr 1, 2014 | 03:02 PM
chaase's Avatar
chaase
St. Jude Donor '12
Get a mechanical gauge and test it. There have been many cases of poor quality sending units out there. The other possibility is that when you replaced the oil pump you crushed the o-ring and it is not priming the oil pump.
Old Apr 1, 2014 | 03:09 PM
savageone's Avatar
savageone
Cruising
thanks ,will check
Old Apr 1, 2014 | 03:54 PM
3boystoys's Avatar
3boystoys
Lots of stories here about the sensor lasting a day or less, especially is it's OVER-TORQUED (15 ft/lbs I believe is the spec). Hard to believe anyone would go through all the hassle of a new pump WITHOUT actually checking the pressure with a mechanical gauge.
To oil pressure problems
