M/T ET Streets: Mounting question?
Old Jul 17, 2002 | 08:28 PM
Green Monster's Avatar
Green Monster
Cruise-In II Veteran
Cruise-In VII Veteran
Default M/T ET Streets: Mounting question?
I have a set of M/T ET Streets that I want to mount on 16" Camaro wheels. The problem is that they are tube type and a local shop says they cant be used with these rims. How do you mount these tires? With tubes? without tubes? Please help me!
Thanks,
Ross Beltle
Green Monster
Old Jul 18, 2002 | 05:07 AM
Green Monster
Default Re: M/T ET Streets: Mounting question? (Green Monster)
ttt
Old Jul 18, 2002 | 07:45 AM
Tom Hall's Avatar
Tom Hall
Mount them without Tubes. Tubes are heavy and cost a lot. You will have to screw your tires to the rim if you use tubes, so if the tire moves on the rim it won't break the valve stem off the tube. The tires may loose some air when not in use, but no big deal.
Old Jul 18, 2002 | 11:15 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: M/T ET Streets: Mounting question? (Tom Hall)
What Tom Hall said is right on. 95% of all et street guys i have spoken with go tubless, including myself. When Wade of ARE ran 9.25s at 150+ in the 1/4 mile he was also running tubeless with his 26x11.5x16 et streets!:D
Nitrovette
To M/T ET Streets: Mounting question?
