Fogs arent working
Old Apr 5, 2014 | 08:40 AM
mtlvette's Avatar
mtlvette
Default Fogs arent working
Hey guys,
I just bought a 02 C5. I noticed that the fog lights won't illuminate. The fuse is fine, and I know the relay (under the hood) is good because i tried swaping with the one next to it (i also hear a click when i turn on the fog switch). The light on the button lights up, but the fogs themselves won't turn on. I find it unlikely that both are burnt at the same time. Is there any other possibility?
Old Apr 5, 2014 | 11:29 AM
rob-cyn's Avatar
rob-cyn
I would check for voltage at that relay. It's a good sign that the light on the switch is coming on. It is very possible the bulbs are bad. These cars are all over 10 years old. They are very easy to get to. I just changed all mine on over to hid. Awesome upgrade for the price.
Old Apr 5, 2014 | 11:32 AM
mtlvette's Avatar
mtlvette
Do i have to get under the car to change them? Any good DIY on this? Also, where did u get your HID's?
Thanks in advance,
Nick
Old Apr 5, 2014 | 11:52 AM
jcgunn's Avatar
jcgunn
Originally Posted by mtlvette
Hey guys,
The headlight switch has to be in parking or higher for the fogs to come on...
Old Apr 5, 2014 | 11:55 AM
mtlvette's Avatar
mtlvette
Lol! I know that
Old Apr 6, 2014 | 03:12 AM
Triple Black 1999's Avatar
Triple Black 1999
Lol! I know that
Went through the same thing with mine last year...Both bulbs were burnt.
Old Apr 6, 2014 | 08:06 AM
mtlvette's Avatar
mtlvette
Ok i'll check the bulbs, anyone have a good DIY? Do i have to get under the car?
Old Apr 6, 2014 | 03:31 PM
mtlvette's Avatar
mtlvette
Ok well i changed both bulbs, still nothing. Any ideas?
Old Apr 6, 2014 | 09:35 PM
rob-cyn's Avatar
rob-cyn
Bought my HIDs off the auction site. Bought digital ballasts. Sounds like you need to get a meter and see if you are getting 12v at the socket which I doubt you are. It could be a bad ground or hot wire. It's not a complicated circuit so it you have a digital meter it shouldn't be hard to find the problem. Have you ever done any electrical troubleshooting before ?
Old Apr 7, 2014 | 08:16 AM
mtlvette's Avatar
mtlvette
I cleaned and tightened the grounds on the frame rails behind the headlights and now everything works. Thanks
To Fogs arent working
