Anyone had this problem?
Old Apr 8, 2014 | 09:20 PM
harleyvette's Avatar
harleyvette
Default Anyone had this problem?
This is the first time it has happened.
Today, returning to my 98 C5 after shopping the key would not turn.
After a little wiggle it turned and the Vette started.
It did this three times today. Has anyone experienced this ? Anyone have a cure?
Old Apr 9, 2014 | 04:13 AM
harleyvette
Originally Posted by 8VETTE7
Couple possible problems could be causing it:
1) Worn key..... Especially if you have a lot of "stuff" hanging from the key ring.
2) Worn tumblers in the key cylinder
3) Fine wire in the key cylinder that reads the resistor pellet on the key may be bent or damaged and interfering with the key and tumblers.
Start by using your backup key or have a new key cut. If that doesn't cure it then a new cylinder will cure both 2 and 3.
Thanks for that info.
