I was interested in buying a used c5 and was wondering what the differences are in the years of c5 and which one i should get. Like i heard from a friend that he thinks from 99 on that all the c5's have the ls6 intake. Not sure if that's true but i just want to know. Thanks to everyone
Re: Differences between the c5 corvettes (c5forme)
Exterior and interior looks wise, all C5s are exactly the same except rims. Heads up display I think wasn't avialable till 99 if you want that. 2000 and up have the LS6 intake manifold, which is no big deal to install on an older vette, and will gain you at least 10RWHP. Some changes to active handling in the new C5s where they have a new and older program, with the system not availble in the early C5s (97, 98).
Fixed roof coupe not available before 99, other than that, I think someone may provide a link, or add to or correct any of my info above.
What you should get? I would say the cleanest and newest one you can fit in your budget of course :D Some of the later years have this oil consumption issues, but other than that, no real bad year for the C5 really.
Just a few differences between '97 and the latest, not including the wheels. Somebody correct me if I'm wrong, I'm doing this from memory. The Corvette black book details all the differences:
- HP and torque increase.
- passenger door lock was deleted starting in '00 or '01 I think
- window clips that keep windows sealed during higher speeds were relocated.
- leather seats side bolsters were redone with vinyl to prevent premature wear starting mid '99.
- HUD not available till '99.
- alternator bracket redesigned for less noise?
- radiator shroud changed from 2-piece to 1 piece.
- weather stripping in rear was redesigned to prevent water from coming in when you open the coupe hatch.
- Something with the tension in the spring in the 6-spd shifter was changed, lighter or heavier.
- headlight motor assembly changed so you can't swap out a bad plastic gear.
Powertrain Highlights:
1997-1998:
LS1 Engines Identical.
1999-2000:
LS1 Engines Identical (some component changes, fuel line changes, programming changes, and injector size changes) Slightly more (undocumented) HP than 97-98's
2000 - NE and CA emmissions, have pre cats
2001 LS1/LS6:
Same intake, Same exhaust manifold, Same Larger MAF Sensor, and same clutch as LS6
Different cam (actually uses the 6.0 liter truck cam) for LS1
pre cats added for all 50 states
Late 2001 LS1 has same short block assembly as LS6
2002 LS1:
Same as 2001 LS1
2002 LS6:
Different Cam, Different Valves/Springs, No Pup Cats, Higher Flow Main Cats, No MAF Screen, different clutch
