HELP!!!Where is the "Clutch Position Switch" located at?
Old Apr 19, 2014 | 02:46 PM
moe24's Avatar
moe24
St. Jude Donor '14
Default HELP!!!Where is the "Clutch Position Switch" located at?
Dose anyone know where the clutch position switch is located it? Or have a picture of it?
Also which one/color of the clutch position switch wires is "+12volt key on"??
2002 z06
Old Apr 19, 2014 | 03:32 PM
bumble-z's Avatar
bumble-z
To see the clutch position switch, you will need to get your head under the dash & look up to the back side of the clutch pedal.
If I remember correctly, you may have to pull the lower knee bolster in order to see and service/adjust the switch
The switch makes contact to a flat spot area of the clutch pedal.
The switch "button" can be adjusted in or out , to make proper contact.
Old Apr 19, 2014 | 05:46 PM
moe24's Avatar
moe24
St. Jude Donor '14
do you know anything about how to install the launch control feature on the lnc-2000?
I pretty much got everything sorted out but in the instructions it says "on most Manual transmission GM cars there is 2 switchs, 1 is the cruise control disable switch at the top of the travel (which I dont use) and the other is the neutral safety/starter enabled clutch switch at the bottom of the travel (the one I need to use)..
I dont want to cut the wrong wires and wanted to see if anyone can provide a picture of which one is which so I can make sure.
Old Apr 19, 2014 | 05:53 PM
moe24's Avatar
moe24
St. Jude Donor '14
My car is a 2002 z06
Old Apr 19, 2014 | 06:44 PM
bumble-z's Avatar
bumble-z
Have you found the location of both switches?
(The cruise & starter clutch switch)
I've never installed a launch controller before.
How ever the starter/clutch switch is on the fire wall directly behind the location of the clutch pedal.
It is a black plastic box around 2" square.
(Inside the car)
It sets just to the right of the dead pedal & just above the carpet.
There is a plunger on it that the clutch pedal makes contact when pushed to the floor.
Don't know what color the wires are.
Old Apr 19, 2014 | 06:53 PM
moe24's Avatar
moe24
St. Jude Donor '14
No I won't be by my car untill tommorow..im trying to get some info in advance on how its suppose to be installed before I get back home..
To HELP!!!Where is the "Clutch Position Switch" located at?
