DCM replacement
Old Apr 21, 2014 | 12:00 PM
2003Evo's Avatar
2003Evo
Default DCM replacement
Yes another DCM issue. I can lock the passenger side door with the FOB and from inside BUT I cannot unlock with either. Reading all the posts I am pretty sure it has to be my DCM.
I have an opportunity to get one from a member off a same model year vehicle/kind.
My questions are:
a) Can I just replace it or does it need to be reprogrammed? In other words I can just swap the modules and everything should work.
b) Do I need a module that matches the part number in mine, or any 2002 module should work? Luckily the module is coming off a same year and kind of car I have (02 Z06).
Old Apr 21, 2014 | 06:40 PM
2003Evo's Avatar
2003Evo
Anyone?
Old Apr 21, 2014 | 07:05 PM
lionelhutz's Avatar
lionelhutz
Any module from a passenger door should work. They all do the same thing controlling the window and mirror.
Old Apr 24, 2014 | 11:09 PM
2003Evo's Avatar
2003Evo
Thank you lionel, got the "new working" one today and it did the opposite. The one i just got all it does it unlocks the door, whereas the original one it only locked ...just going to swap the relays at this point
Old Apr 25, 2014 | 07:59 AM
n8dogg's Avatar
n8dogg
Sounds like both DCMs are bad. Swapping relays inside the DCM may be a waste of time considering both modules seem bad.
If the replacement module you got was in fact "brand new", I'd exchange it. Sounds like someone put their old one in the box and sent it back.
Old Apr 25, 2014 | 09:14 AM
2003Evo's Avatar
2003Evo
N8Dogg, the description from the buyer was as in working condition. Bought it off a member here from a part out, so its not new. New to me that's all lol...both modules work fine but one doesn't lock and the other doesn't unlock.
I will just swap the unlock relay from the working module to the one with the bad unlock relay.
Old Apr 25, 2014 | 09:18 AM
chaase's Avatar
chaase
St. Jude Donor '12
It could be a wiring issue and not a module issue. The wires in the accordion have a tendency to lose insulation and cause erratic behavior.
Old Apr 25, 2014 | 09:27 AM
dadaroo's Avatar
dadaroo
Why swap relays when new ones are dirt cheap?
NEC EQ1-31000S For the windows
The Digi-Key part number for the door relay is 255-1240-ND
Old Apr 26, 2014 | 12:09 PM
2003Evo's Avatar
2003Evo
Got it to work and swapped relays at my work lab, the guy did it in 10min. Now i have working lock/unlock. Good thing is i have an extra module and will be replacing the relays on the extra module and have a spare one.
2003Evo's Avatar
2003Evo
Didnt want to wait for delivery
To DCM replacement
