mods done, now how do I go about getting programming done
Donaldson Blackwing Intake system
Powerduct
Belanger Headers
X pipe Bassani
Corsa Indy Pace exhaust system
Thermostat fan and fan controller w/adjustable controller
LS 6 manifold w/accessories
Katech Head and Cam package STage 2 with ported throttle body
Underdrive Pulley
Gears:
TC sy3500
Z0 6 fog light screens
lowering bolts.
I get the car back on Monday.
Any help appreciated
[Modified by Naylin, 5:22 AM 7/20/2002]
Powerduct
Belanger Headers
X pipe Bassani
Underdrive Pulley
Gears:
TC sy3500
lowering bolts.
My saga is illustrative. My first H/C setup from Agostino Racing came with "custom" SuperChips programming. It was off from day one. A variety of codes relating to Air/Fuel management, suboptimal drivability, and less than maxiaml power/torque. I first tried the bandaid approach of adding a MAFT, which helped a bit, but not enough. I even spoke with SuperChips about altering their program, to no avail. Finally, I drove to Ed Wright's shop in Tulsa where he dyno tuned the car. I gained an immedite 30hp, and cured all the drivability problems. Subsequent to this, Nick sent me a whole new LS6 H/C package which is now installed. Ed is in the process of reprogramming my PCM to accomodate this much more radical setup.
The process of my reprogramming is an example of what he could do for you. We've run the car on a dyno with wide band O2's and have sent him the graphs and A/F measurements that have resulted. I'm also sending him some auto tap logs from driving about town. He'll then reprogram a computer, knowing that we're using the program he created for us as our baseline. I expect we'll go back and forth a time or two, but should end up with something close to, or identical to, what we could do if I drove back to his shop.
In your case, I'm sure he knows KaTech's stuff well. He would need cam specs, and will ask you to detail all your other mods. He can then create a program for you, which you could fine tune, if you wanted to spend the time, in a way similar to mine above. The result will be far better than what you'll get from Super Chips (my opinion, though many on the forums share it).
Hope this helps.
That will take a few weeks won't it. I have the autotap/EFI live software so can run the car with this and can get dynos done in NZ by an autoshop here. Thanks, I have contacted Ed Wright.
[Modified by Naylin, 5:21 AM 7/20/2002]
