Harmonic Balancer Question
Old Apr 27, 2014 | 10:38 AM
Jumper11's Avatar
Jumper11
Default Harmonic Balancer Question
I am one of the many who experienced balancer wobble. Mine was the rubber was coming out so before it failed I decide to change it. Info from the forum led me to a powerbond SPI balancer. No where like the stock one. I followed the book and marked the balancer an crank prior to removal. But to my surprise the new balancer didn't have any holes or places to add weights. I didn't have a reference to install the new balancer so my question is; Will my engine now vibrate? I installed the new balancer per the book but just picked a spot an installed it. OBTW I also changed the front seal both tensioners an pulleys just because I had easy access. I hope I don't have to pull it all apart an do trial an error.
Old Apr 27, 2014 | 11:04 AM
Patches's Avatar
Patches
You will be fine, assuming you installed it correctly as far as spacing on the crank and torque values (and that you used a new bolt, either stock or ARP). I have installed lots of these pullies over the years, stock and aftermarket, and never had one throw the engine balance off. The aftermarket pullies are zero-balanced.
Old Apr 27, 2014 | 01:52 PM
StingrayRebel's Avatar
StingrayRebel
check your factory balancer and see if it has any added weights on it... if it does take that off and put it on the new balancer and install it in the same orientation as the original balancer was... most of us seem to have internally balanced engines so if there are no weights on the factory balancer you can put the new one on in any spot... I did mine this way and had no issues
Old Apr 27, 2014 | 06:37 PM
Jumper11's Avatar
Jumper11
I heated up the core and put antiseize on crack. I ran it down until it stopped. I used a new ARP bolt and torqued it to 235 ft lbs. The belts and pulleys align and will complete the install this week. Too many honey doos to be stuck in the garage all weekend. Thanks for the reply..
Old Apr 28, 2014 | 01:58 PM
thbwlZ's Avatar
thbwlZ
the first question is:
is your vette a manual or an automatic?
Old Apr 30, 2014 | 07:14 PM
Jumper11's Avatar
Jumper11
Manual Why? I ran the balancer down all way down, completed the job and all looked great. Do I need to get the front end aligned? I did not break the jam nuts on the tie rods but don't know if I rotated the tie rod end 360 degrees. Thanks for all your help.
Old Apr 30, 2014 | 08:36 PM
Jumper11's Avatar
Jumper11
OK here's an update. Pulled the rack and HB and replace both pulleys and tensioners and front seal. Recommend doing it because you already there. Got a puller and remove the old balancer. replaced it with a SPI powerbond HB. Did not have a keying kit so I installed as the OEM manual. Replaced everything and finished the job. All went well. Glad I attempted it myself not too hard and very rewarding.
Old Apr 30, 2014 | 08:49 PM
Jumper11's Avatar
Jumper11
Just one question. Do I need to get the front end aligned? Steering will is straight and the car tracks straight. Don't want to destroy any tires.
Old May 1, 2014 | 01:32 AM
StingrayRebel
I wouldn't worry about it, I moved my rack over to the side when I did my cam and haven't had it aligned since with no issues... as long as you didn't break the tie rod ends loose where they go into the rack I think you will be fine... I have no idea why the guy above asked if it was an auto or manual, I really don't think it matters unless he was going to give some advice about tightening the crank bolt
Old May 1, 2014 | 06:56 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It matters because IIRC, it's the manual transmission cars that have the extra balance "weights" added to the crank pulley, whereas the auto cars don't.....or vice versa.
Old May 1, 2014 | 09:40 AM
thbwlZ's Avatar
thbwlZ
yep.
I asked because only the LS engines for manual transmission vettes were taken through the post assembly, fine tune balance procedure, where weights were added to the flywheel, damper, or both, as needed. Engines used in vettes with automatic transmissions were not. The manual cars were more sensitive to harmonics from very slight engine imbalances. Even though the engines are balanced good enough for reliable engine operation, you could still sometimes feel vibrations. So they took these engines a step further and externally balanced them to an even lower imbalance tolerance.
If the OP had an automatic, it would be a moot point. Having said that, if he has everything back together, has run the engine or driven it, and doesn't feel any new vibrations in the car, he is fine. Most, if not all, of those aftermarket dampers don't even have the circumferential balance weight receptacle holes anyway.
If he ever changes his clutch and flywheel, he will want to pay more attention to any weights he might have in the stock flywheel.
Old May 1, 2014 | 08:33 PM
Jumper11's Avatar
Jumper11
Its a manual, got it all together and it drove fine just around the hood. I'm taking it to work tomorrow and I'm confident it will be fine. Thanks guys. when I do the clutch I will be especially careful with the fly wheel. Hopefully not for awhile.
Old May 2, 2014 | 12:43 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Do yourself a favor and buy a ATI balancer and forget the powerbond. After lots of research I decided to sell the one I just bought new. I spoke to Katech and they set me up.
Old May 2, 2014 | 08:29 PM
Jumper11's Avatar
Jumper11
Too late. Powerbond has good reviews. I don't race the car or drive it hard. I do at time get on it but not beat it. Everything installed better than they came apart. I'm happy. Thanks.
To Harmonic Balancer Question
