[PRODUCT] Pocket DYNO
Old Jul 19, 2002 | 03:28 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default [PRODUCT] Pocket DYNO
Check it out: Plugs right into your PDA... Very cool....
http://www.pdyno.com
Old Jul 19, 2002 | 03:54 PM
jeffh355's Avatar
jeffh355
Default Re: [PRODUCT] Pocket DYNO (y2k02c5)
Hey! That's :cool:
Old Jul 19, 2002 | 03:57 PM
EuG's Avatar
EuG
Default Re: [PRODUCT] Pocket DYNO (jeffh355)
Wow! Way C:cool::cool:L!
Looks like it got much better features than G-Tech.
Only wish it would work with laptops as well!
[Modified by EuG, 2:57 PM 7/19/2002]
Old Jul 19, 2002 | 04:09 PM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: [PRODUCT] Pocket DYNO (EuG)
Now THIS is cool!!!!! :eek:
I want one!! :D
Old Jul 19, 2002 | 04:25 PM
silversport's Avatar
silversport
Default Re: [PRODUCT] Pocket DYNO (MattG)
I want one!! :D
Do I smell a new product about to be offered by Exit28??? :chevy
Old Jul 19, 2002 | 04:41 PM
Miles in Michigan's Avatar
Miles in Michigan
That is a cool product at a good price.
I wonder if they have 3 orthogonal accelerometers, since they don't say it has to be leveled perfectly? If you have two only, the thing has to be level or the effects of gravity cannot be taken out.
Here's a two-axis accelerometer that's pretty cheap: http://shop.store.yahoo.com/crossbow/adxl202eb232.html
It doesn't come with software (you've got to write your own), and it isn't in an enclosure. It's got an RS232 serial cable, so it'll hook up to a laptop (or maybe some handhelds?). I'll probably throw together some software to use it for time-to-speed and time-to-distance recording, but it'd be under Linux not MS windows.
I bought it to use for a navigation system I built, but ended up not using it since I couldn't find cheap enough gyros for accurate attitude information. It's been sitting in a box for a few months.
Old Jul 19, 2002 | 07:38 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: [PRODUCT] Pocket DYNO (Buckmaster)
where do ya buy it ? how much ??
Old Jul 19, 2002 | 07:53 PM
RyanD's Avatar
RyanD
Default Re: [PRODUCT] Pocket DYNO (Miles in Michigan)
If you read the manual, it says that it has to be relatively level or it will give you an error when you start the test. It then calibrates itself to take into account any small amount of tilt. A G-Tech works the same way.
Old Jul 19, 2002 | 08:00 PM
Miles in Michigan
I looked in their FAQ, and it is a 2-axis accelerometer, so mounting it level is important.
Actually, if it's not level, it could detect during initialization any perceived acceleration while stopped, and determine the deflection from verticle. For example if it detects 0.7g along the forward axis and 0g on the lateral axis, then it knows it is mounted at 45 degrees facing forward, and level horizontally (assuming a level road). Then if the forward axis changes to 0.8g, you'd take (0.8-0.7)/cos(45)=0.1414g, and get the forward acceleration component. You still can't mount at any angle, but up to 45 degrees off of flat it should still be accurate, and there'd be no bias.
I don't know if theirs does that, but I know mine will, now that I've thought of it. :D
Old Jul 19, 2002 | 08:14 PM
Miles in Michigan
Default Re: [PRODUCT] Pocket DYNO (RyanD)
Yeah, I saw the "relatively level" line, but thought they would have said "very level" if only a 2-axis unit, until it occured to me how easily the error could be removed.
Do you have one of these? Is it a proprietary plug to connect to the palm? Is there some way to log data coming across this palm connector, like you can with a terminal emulator on a serial port?
I'd be curious to see if they are just sending the accelerometer's readings at a fixed rate and analyzing them on the Palm, or if they have a processor inside the unit that integrates the acceleration into speed and distance at a high rate, and then only sends the results over.
Even if the accel data comes across at a high rate, as long as the incoming port is buffered, you wouldn't lose any, unless the OS waits a really long time to get around to handling it. And if it came at a fixed rate, then your application wouldn't need to time stamp samples, it'd use the (known) fixed time delta that the unit sends data at.
Maybe I'll ask them, but they might not give out details so no one copies their design and tries to sell a competing product.
Old Jul 19, 2002 | 08:40 PM
99 Corvette's Avatar
99 Corvette
Anyone know if it is only for the Palms or it will work with other PDAs like a Compaq iPAQ :confused:
Jerry
Old Jul 19, 2002 | 09:16 PM
Miles in Michigan
Default Re: [PRODUCT] Pocket DYNO (99 Corvette)
The website says it only works with PalmOS. I don't know which PDA's use PalmOS besides Palms, if any.
Old Jul 19, 2002 | 10:55 PM
RyanD's Avatar
RyanD
It says it works with Handspring as well.
Old Jul 19, 2002 | 11:17 PM
66ImpalaLT1's Avatar
66ImpalaLT1
Palm does RS232. Its a pretty easy platform to develop software for. I've played with it a little bit.
Let me know when you're making progress with your software for linux. I'll probably buy one and play with it too.
Eric
Old Jul 20, 2002 | 02:08 AM
Miles in Michigan
Default Re: [PRODUCT] Pocket DYNO (66ImpalaLT1)
Is that an RS232 port in the bottom of the palm?
Cool, I'll remember to email you when I get something put together. Are you getting a Pocket Dyno, or an ADXL202EB-232 like I linked to? If you're going for the ADXL202EB, I thought I'd tell you that there is a version without the RS232 interface that is much cheaper (about $40). I hate soldering so I got the version with serial built in.
Old Jul 21, 2002 | 12:20 AM
pocketdyno's Avatar
pocketdyno
1st Gear
I am willing to answer any questions that you may have about the PocketDYNO. My email is email:brennan@pdyno.com. I can also provide some results that I have from testing my friend Brian's Z06.
Old Jul 21, 2002 | 01:11 AM
YLWFVR75's Avatar
YLWFVR75
Default Re: [PRODUCT] Pocket DYNO (pocketdyno)
:cheers: Glad to see a product representative! Welcome to the Forum! Get ready for a stack of questions, and possible orders! :)
Maybe we can run a Group Purchase deal! Please let us know!
Zack
Old Jul 21, 2002 | 03:17 AM
EuG's Avatar
EuG
Brennan,
welcome to the forum.
Is there any way to make this unit work with PC (laptop)???
Or at least, do you have any plans for future PC support?
Old Jul 21, 2002 | 05:03 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
I think the new G-Tech competition for $249 has more features and could be more useful since you can put it on the dash, it has a tach, lights for shifting, etc. Unfortunately, I got a few weeks ago but am sending it back. Some problems are that it is hard to read in daylight, is hard to calibrate, and the shifting lights won't work after about 5200 rpm. I wrote to them with some suggestions and they said that all but one were being put into their upgraded system which should be out in a couple of months.
Anyway, I have to say that the G-Tech Comp could be a great unit when they get the bugs worked out. I've considered keeping it for the updated changes but have decided it would be better to return it and maybe buy the improved one later. By the way, when the shift lights did work, they were pretty cool and you didn't have to watch the tach or HUD.
This PocketDyno looks easier to use and is a little cheaper ($199) but requires a hand-held palm and, again, doesn't have all the features of the G-Tech Comp.
Just my impression of the two.
To [PRODUCT] Pocket DYNO
