Intake Maniflod
Old Apr 28, 2014 | 04:17 PM
NC5's Avatar
NC5
7th Gear
Default Intake Maniflod
New to posting threads. Have 99 z51 with what I think are bad knock sensors. Going to replace the sensors and while I had the manifold off I want to replace it with a z06 style. But I cant seem to find much info on what brand to buy. Any help would be greatly appreciated. I have a about 800$ i can spend on a new intake. Thanks
Old Apr 28, 2014 | 05:42 PM
NukeC5's Avatar
NukeC5
Best bet is to buy used. Look on craigs list and ebay. usually go for $400. The LS6 intake has a flat bottom. LS1 has a rounded underside FYI.
Old Apr 30, 2014 | 08:54 AM
Lt. Dan M.'s Avatar
Lt. Dan M.
I just did an LS1 to LS6 intake swap out. There are cooler lines run under the intake that will not fit under the LS6 intake without some modification. I used a dremmel tool with a small cutoff wheel and just cut the ribs off that were in the path of the coolant lines. Took me an hour or os as I wanted to make it look like it was made that way. While you have the manifold off you should think about doing an oil pressure sensor relocate. Fairly easy to do, but I would stay away from using any plastic lines that can crack or melt, as I have seen some use. I have seen some pretty good deals on LS6 manifolds on here, $ 300 to $400. No need to spend and extra 4 or 5 hundred on an intake that you could use on other mods. Good luck.
Old May 5, 2014 | 09:07 AM
NC5's Avatar
NC5
7th Gear
thanks for the help. is there any other way to identify ls6 from stock intake other than the bottom being flat
Old May 5, 2014 | 09:29 AM
Smoken1's Avatar
Smoken1
From what I have read all 02 and newer C5's came with LS6 manifolds.My 02 vert has one
Old May 5, 2014 | 09:32 AM
3boystoys's Avatar
3boystoys
Not worth the hassle for the 5HP IMO. Better ways to spend $800.
Old May 6, 2014 | 02:48 PM
NC5's Avatar
NC5
7th Gear
Thanks for all the advice. I have been searching for more info on the ls6 intake. Im still concerned that i will buy the wrong one. Does the ls6 have the flat underside? And my 99 have the rounded one? Also I found the part numbers on the DS of intake to help identify.
99-00 c5 12556333
01-04 c5 12573572 ?! This the one i need correct?
01-02 F body 12561184?! This one has the egr correct?
Just dont want to buy what i already have or what I cant use.
Thanks again for your help.
Old May 6, 2014 | 10:01 PM
NukeC5's Avatar
NukeC5
There are three LS6 intake cast numbers:
12561182
12561184
12573572
The stock on a 99 would be 12556333. 12561184 is the F-body intake that has been the most sought after. It supposedly outflows the other castings by a few CFM.
And no, there is no EGR on the later model F-bodies.
Old May 6, 2014 | 11:44 PM
TGO's Avatar
TGO
Yeah if you're gonna get a new intake manifold at least buy a ported one.
Old May 9, 2014 | 11:47 AM
dr_whigham's Avatar
dr_whigham
No FBody 2001-2002 ever came with EGR, and they came with "LS6" intakes from the factory.
All "LS6" intakes are the same and flow the same. Look for the ribs, and make sure there's no EGR hole.
Old May 9, 2014 | 07:25 PM
baxsom's Avatar
baxsom
If you are willing to spend 800 bucks get a used FAST and be done with it.
Old May 13, 2014 | 06:16 PM
NC5's Avatar
NC5
7th Gear
I have another question. Will I need a tune after this?
Old May 13, 2014 | 06:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
x2 baxsom
Make sure you use only AC Delco knock sensors and replace the harness learned that one the hard way.
Old May 13, 2014 | 06:57 PM
123sugey's Avatar
123sugey
Dig
If your planning other motor mods buy a used FAST intake. If not... Save your money
Old Jun 5, 2014 | 02:16 PM
Jims79's Avatar
Jims79
You can find used LS-6 intakes for half of what you have to spend and in my option its cheap HP and well worth it. And to answer your question no tune needed. This is an old thread I hope you have it done already.
To Intake Maniflod
