Fuel Pressure Sensor Fitting
Problem solved, parts on order. Just incase anyone ever has this problem or would like to install their sensor elsewhere, here are the parts I ordered:
Russell 644120: 6an male to 3/8 quick disconnect (goes on fuel rail where line snaps on)
Russel 670340: 6an female to 6an male with 1/8 npt port (screw onto the above part, screw pressure sensor into 1/8 side port)
Then a part I found on eBay: 3/8 push connect to 6an female (screws onto above part, then fuel line snaps back onto 3/8 side) can be found here: http://www.ebay.com/itm/281291998924
Will update once parts are in and installed
EDIT: Just use Russell 640730. It is one single piece that accomplishes all that I was trying to do. I jumped the gun a little too quick.
