airbag and control module help
Old May 4, 2014 | 03:05 PM
musclecarsrock68's Avatar
musclecarsrock68
Default airbag and control module help
Hey guys I got a 99 corvette that was in a wreck, Both airbags went off and the damage was fixed, but now I need to replace the air bags to get the title back so I have a few questions.
Where is the airbag control module? I have herd under a seat, under the center console, and under the radio..
Is there any sensors that need to be replaced?
and does the entire dash have to come out to replace the passenger side air bag?
Thanks for any input!
Old May 5, 2014 | 09:13 AM
dadaroo's Avatar
dadaroo
The control module is under the HVAC/Radio area. The control module IS the sensor. It may be fine and just needs to be reset by a Tech II.
You do have to remove the dash pad for the passenger side air bag. It is easier to remove than it sounds like. I know at least two people who are NOT routine DIY guys that have done it and found it not that hard. Just bag and tag all the fasteners so you know where they go.
http://tech.corvettecentral.com/2013...-dash-removal/
Old May 5, 2014 | 06:36 PM
musclecarsrock68
Awesome thanks for the reply.
So is that metal box with the yellow plug what i need to have reset? I won an acution on ebay for 40$ that says they will reset it since I dont have the means to do it myself. Has anyone else ever done it through ebay? and ill give that link a read when I get off work thanks again!
Old May 6, 2014 | 07:26 AM
dadaroo's Avatar
dadaroo
Yes that is the module. My FSM says you need to remove the HVAC control unit to remove it. Maybe, maybe not.
Not sure about resetting the module and whether it can be done external to the car.
To airbag and control module help
