Hurst shifter install goes really wrong!
Old Jul 20, 2002 | 09:38 PM
Jackal's Avatar
Jackal
Default Re: Hurst shifter install goes really wrong! (OCMike)
DUDE!!! That really sucks...sorry to hear that...
I started my shifter replacement today, and when I got everything off, guess what, there was Mold everywhere. the previous owner must have spilled somthing in there, and never cleaned it up. Its horrible....
Old Jul 20, 2002 | 10:22 PM
GTP's Avatar
GTP
Default Re: Hurst shifter install goes really wrong! (Jackal)
Just an update: Found a new boot for $50.00 and a forum member sold me a ****/key for $25.00 shipped. In the meantime my makeshift shifter fell apart so I went to Pep Boy's and picked up a ricer special anodized Type R shifter. God I feel so goofy at a stoplight. I keep my hand on the shifter so noone looks in and see's it. I also cover the **** with a shirt when I park it. But now with a real **** on I can truly feel the difference the Hurst made. I still consider this a worthwhile upgrade even if it was a pain in the butt. Shifts are much more solid now. The 1-2 and 2-3 shift are awesome. I decided to go with just the light outter springs installed and it seems to work great. I carry a allen wrench with me until I get the spring setting exactly where I want them. Thats the only positive thing about not having a shifter boot installed yet is that I can make quick spring adjustments at the stoplight. Thanks to Shawn at L.A.P.D. for getting me the Hurst after the long wait.
Thanks,
Aaron Lephart
Old Jul 20, 2002 | 10:47 PM
Cyrus's Avatar
Cyrus
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Hurst shifter install goes really wrong! (GTP)
Unbeleivable!!! Glad you finally got it! :eek:
Old Jul 21, 2002 | 01:14 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Here's all the information you "WOULD" have needed to save yourself a lot of frustration.
It's a little like reading the instructions after all else fails, though.
http://forums.corvetteforum.com/zerothread?id=312883
Some simple advice: Don't underestimate the amount of information that is free for the reading on Corvette Forum.
There's not much you can experience with your Vette that someon else here hasn't already experienced and posted here.
Glad you got your shift **** off. Wish you'd read my post before going to all that trouble.
Best regards.
Old Jul 21, 2002 | 04:26 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Hurst shifter install goes really wrong! (VetNutJim)
What a disaster :eek: My demon key came out so easily I couldn't understand what everyone was talking about. Then after the install I put it back in and even tapped on it and it still came out easily the second time by just prying on the left edge.
Anyway, all of my stock stuff is saved in a box because I got a Ken King short boot and aftermarket ****...and it looks like you took a similar route... so at least it's finished and you don't need to save the broken stuff. But still...I really feel for your frustration...when things go bad and then get worse it can sometimes be overwhelming. Glad it's over.
Old Jul 22, 2002 | 12:28 AM
BigBlue's Avatar
BigBlue
Default Re: Hurst shifter install goes really wrong! (FunDriver)
My dad and I tried to replace just the know with a new one. We broke one side of the key off. Now I don't know how we will ever get the thing off. Maybe a set of vice grips or something?
Old Jul 22, 2002 | 12:54 AM
VERTVETTE's Avatar
VERTVETTE
Default Re: Hurst shifter install goes really wrong! (QuickSilver97)
:eek: That's probably the worst shifter install story I've heard to date on here!
Man what a nightmare.
Old Jul 22, 2002 | 01:48 AM
golfnwatchesnc5s's Avatar
golfnwatchesnc5s
Best regards.
I agree on the information available, however I researched and collected info including that post when I removed my demon key. It still took almost an hour and several colorful verbal expressions before it came out! I guess, as per other dimensional tolerances that the General requires from its subs, if you're the unlucky slob with the combination of a Shifter shaft keyway being dimensionally on the lower end and your "demon key" is on the upper end, be prepared to get frustrated! I wonder if GM has a tool for their service personnel!
[Modified by golfnwatchesnc5s, 11:50 PM 7/21/2002]
Old Jul 22, 2002 | 01:51 AM
Noggles's Avatar
Noggles
From: Adventure, excitement ... a Jedi craves not these things.
Cruise-In VII Veteran
Another brilliant GM design plan -- the demon key :mad
I'm sorry yours went so bad. My install was easy except for trying to get the key out, but luckily it came after about 15 minutes of encouragement. :rolleyes:
Old Jul 22, 2002 | 07:26 AM
JeffMc's Avatar
JeffMc
It took me over 5 hours to remove that key. Ended up drilling it out.
- JeffMc
Old Jul 22, 2002 | 11:06 AM
MDT's Avatar
MDT
My post won't help Aaron, but maybe somewhere down the line someone else may benefit...so here goes.
First, in my install, the 2 screw driver method, prying alternately with one, then the other, to produce a rocking motion worked just fine.
But the tip that some member (don't recall who it was) posted a long time ago, seemed pretty ingenious to me and has stuck in my mind. He improvised a slide hammer by removing the adusting bolt from the handle of the vice grips and replacing with a length of threaded rod; the length being sufficient to accomadate a weight of some sort (I've forgotten what he used), then a nut on the end of the rod for the sliding weight to hit against.
So anyone that runs up against a case where the pin will absolutely not budge might want to consider the slide hammer tip.
I do apologize for being unable to give credit to the original poster. Maybe he will read this and come on board with a first hand account.
Good luck.
Mark
Old Jul 22, 2002 | 11:28 AM
luvinc5's Avatar
luvinc5
Default Re: Hurst shifter install goes really wrong! (MDT)
It seems in hindsight I was one of the lucky ones with a relatively easily removed **** key.
Your installation of the Hurst shifter was an interesting reading. Glad to read everything work alright in the end.
Old Jul 22, 2002 | 11:32 AM
  #33
Fahtrim's Avatar
Fahtrim
Default Re: Hurst shifter install goes really wrong! (YELLOHHH)
:eek:
Old Jul 22, 2002 | 12:27 PM
  #34
zrchris's Avatar
zrchris
The effort to remove the key varies greatly between cars. But in every case, all it takes is a medium-sized pair of curved-jaw vise-grips clamped tightly on the sides of the key. The front "teeth" of these vise grips are about parallel when set at the width of the key, which is the key to maintaining a tight grip that won't slip off. Pull up on the vise-grips as you hit the side of the vise grips near the jaw with a 1-2 lb hammer. Sometimes pulling side-to-side does the job, but tapping with a hammer will definitely do it.
Old Jul 22, 2002 | 04:13 PM
  #35
Vetts Forever's Avatar
Vetts Forever
...So I do what any other pissed off guy would do and grab a torch...
:eek: :eek:
Old Jul 22, 2002 | 08:17 PM
  #36
NICEDRV's Avatar
NICEDRV
I used vice grips to get mine out, and the grips slipped off. I was pulling so hard that it came back and smacked me in the mouth. Big FAT lip and alot of blood.
Old Jul 22, 2002 | 08:21 PM
  #37
John Wiz's Avatar
John Wiz
Default Re: Hurst shifter install goes really wrong! (luvinc5)
Mine also came out very easy. The only reason was that I was lucky enough to be at the plant while mine was being built and asked the guy doing the shifter not to pound it in too hard (I had read all the horror stories on here). He just tapped it in enough to get the cover on. Came out with a light pull with pliers :D . The stock know is now sitting in a box with the stock shifter.
Wiz
