Squeaky brakes ??
Old Jul 20, 2002 | 11:31 AM
IMQUIK's Avatar
IMQUIK
Default Squeaky brakes ??
2001 coupe with 11,000 miles stock brakes.No hard driving (on the brakes)
When I come to a stop, at 3-5 mph it squeaks, sounds like sh?!.
How can I fix? :mad
Old Jul 20, 2002 | 12:59 PM
redriverjohn's Avatar
redriverjohn
Default Re: Squeaky brakes ?? (tshac)
Sounds like the pads could be glazed. Usually block sanding them will stop the noise, if that's the problem. Maybe someone else with more brake expertise than I have (which would't take much) could chime in here and give you some real help.
Old Jul 21, 2002 | 12:33 AM
gmblack3's Avatar
gmblack3
Default Re: Squeaky brakes ?? (redriverjohn)
You could also try to rebed the pads before you remove them. Try 6 stops from 60-30 and 4-6 more from 60 to 0. Do not lock the brakes up and cause the ABS to come on. Just good hard pressure. Drive around after and let the brakes cool down and park the car for the night.
If they still squeal then remove and sand them to get rid of the glazing:
http://forums.corvetteforum.com/zerothread?id=345623
To Squeaky brakes ??
