Po 171 & 174 codes
Old May 7, 2014 | 06:21 PM
Cameldog's Avatar
Cameldog
Default Po 171 & 174 codes
Ihave a bone stock 2001 C5, just turned 100,000 miles. It started throwing the PO171 & 174 codes. When I first looked under the hood one of the clamps on the air filter housing was loose. I cleaned the K&N filter element & cleared the code. The codes came back so I put in a stock air filter, cleaned the MAF & checked for leaks from the air filter to the throttle body. I looked for vaccum leaks as well. Cleared the codes. Now if I start the car cold and drive 10 miles or 100 miles the light does not come on as long as I don't shut the engine down and restart it hot. ANy time the engine is restarted hot the check engine light immediately comes on. I bought a new fuel filter to put on this weekend. If that doesn't work, my next step is to take it to the dealer unless y'all have some other suggestions.
Old May 7, 2014 | 09:48 PM
Dcollins3208's Avatar
Dcollins3208
I would tighten every single clamp from throttle body to intake, and check the throttle body and intake bolts. Check the PCV tubing as well
Old May 8, 2014 | 09:33 AM
3boystoys's Avatar
3boystoys
You need to get a scanner on it and check the output of the O2 sensors and the ST and LT fuel trims. My truck was throwing these codes and my front O2's were very lazy and the Fuel trims were at their max. Replaced the O2's reset the fuel trims and all is well.
Old May 9, 2014 | 03:44 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Most of the time it is a broken vacuum line or pcv line rubber elbow.
Old May 10, 2014 | 10:22 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
If you don't find any vacuum leaks, Freeze frame data would be a big help. Come inexpensive scanners will provide it. If it set at idle, you probably would notice it running a little rough on initial cold start until front o2's are hot enough to function. You can use carb cleaner or propane to find the leak if looking and listening didn't. If the freeze frame data shows tps of 8% and more than about 1200rpm then it's probably the MAF sensor.
The fuel filter could also cause a part throttle lean condition, but if that was the case the car would just lay down at full throttle.
Old May 11, 2014 | 04:44 PM
Cameldog's Avatar
Cameldog
Thanks!Y'all are great! There is a hole in the elbow of the PCV line.Name:  vette hose.jpg
Old Aug 24, 2014 | 01:00 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Read this on another forum....
you should turn the ignition on but keep the motor off, remove fuses 16 and 23, then turn the ignition off, and replace the fuses.
These codes basically result from unmetered air bypassing the MAF. Removing the fuses will reset to baseline numbers and allow the computer to "learn" the new mixtures.
Anyone?
Old Aug 24, 2014 | 11:08 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
The computer will relearn by itself, quickly. If you put a scanner on it, you would see the STFT go negative followed by LTFT dropping until it's back to normal.
Old Aug 25, 2014 | 12:37 AM
JrRifleCoach
So then, most likely I have an air leak after the Blackwing installation?
To Po 171 & 174 codes
