throtle responce
Old May 9, 2014 | 10:05 PM
who928's Avatar
who928
Default throtle responce
A friend called me and said when he stabs the gas car falls on its face and goes nowhere. he said if he takes his foot out of it and brings it up slowly it seems to act normal. Had him check for codes ,none appeared. His cruse control and the rest of the stuff works fine. My 01 never had any problems like that. His is an 04 automatic. Any body have any ideas on what could be causing it not to take off hard.
thanks guys
Joe
Old May 10, 2014 | 01:06 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Traction control on old tires?
Old May 10, 2014 | 01:59 AM
baxsom's Avatar
baxsom
Has it always done this or is it a new problem?
Old May 10, 2014 | 09:46 AM
who928's Avatar
who928
No this problem just started. I thought it might have something to do with the TPS but not sure. He said he has to baby it till he gets up to speed. He can't take off normally. I'm going today and look at to see if I can see anything. I'll try to check the voltage at the TPS.
Joe
Old May 10, 2014 | 12:01 PM
onlyavette's Avatar
onlyavette
Fuel pressure test.
Old May 10, 2014 | 02:41 PM
JrRifleCoach
Maybe check the last time the fuel filter was replaced?
Old May 10, 2014 | 04:22 PM
johnnyzvette's Avatar
johnnyzvette
I'm having the exact problem with mine, I believe my traction control or active handling is kicking in for no reason. Occasionally when it happens, my DIC displays "active handling" I've checked and replaced several parts but still have the same problem.
Old May 10, 2014 | 08:38 PM
who928's Avatar
who928
Looked at friends car today , checked voltage on
TPS it was ok . I did notice one thing, the connection on the MAF was not clipped on all the way . Might be the problem? It did set a code before we checked all connections. It was PCM P0101 H. We'll see what happens . Thanks guys Joe
To throtle responce
