Fast102
Old May 11, 2014 | 07:19 PM
xzo124's Avatar
xzo124
Default Fast102
How much could be expected from going from an LS6 intake , PP throttle body to a FAST102 and maybe a 92mm TB already have all bolt ons making 407rwhp....xzo
Old May 12, 2014 | 02:02 AM
Last C5's Avatar
Last C5
Not that much. To take advantage of the 102 you're going to need a cam and headers. Incidently, if you're going to put a 92 TB on a 102 make sure you use a transition ring or you're going to get a stumble on acceleration.
Old May 12, 2014 | 12:08 PM
xzo124's Avatar
xzo124
got A4 AI heads cam headers xpipe axelback 3.42s 232/236/595/601/113....xzo
Old May 12, 2014 | 04:14 PM
RonSSNova's Avatar
RonSSNova
The biggest issue with the 102 on the C5 is fitment under the cowl. Some get lucky and it fits. Others, like me, need to lower the engine either with mounts or by shimming the cradle.
I'd also recommend the 90mm GM LS2 TB. With adapter harness it's plug and play.
I can't speak definitively to the power gain. You will get every answer under the sun on that topic......but, I believe it's the best intake available.
Ron
Old May 12, 2014 | 08:19 PM
Lpe403's Avatar
Lpe403
Ron
And if you don't want to lower the river, you can raise the bridge by going with an MCM hood.
Old May 12, 2014 | 09:00 PM
RonSSNova's Avatar
RonSSNova
Has nothing to do with the hood. It runs into the cowl area.
To Fast102
