Does this sound correct?
Old May 13, 2014 | 08:10 PM
Mustang_Guy's Avatar
Mustang_Guy
Default Does this sound correct?
I ordered new Drl's and decided to go with the switchbacks after reading on Here about them.so I ordered some and they came with the big gold resistor/ load leveler.I also went ahead and ordered some LED's for the brake/tails and put them in just to see if I'd get the annoying hyper flash (read on here some do some don't) and unfortunately I did.so I ordered 4 more of the load levelers/resistors for the rear tail lights.
My questions are (1) do I need one resistor on each led bulb?(2)where do you wire these in at and to which color wires for a 1998 C5?
Old May 13, 2014 | 11:07 PM
Mustang_Guy
Really?!?!?! No one else has led bulbs in the rear?
Old May 13, 2014 | 11:44 PM
GCG's Avatar
GCG
The hyperflash harness is a better solution. It's plug and play and all your LEDs will be fine.
Sent from my DROID RAZR using IB AutoGroup
Old May 13, 2014 | 11:47 PM
lionelhutz's Avatar
lionelhutz
100%
Forget about using the failure prone resistors.
Old May 14, 2014 | 01:11 PM
Mustang_Guy
While I'd love to take that advice and eventually probably will.
I'd like to use what I have already purchased and received.
Which wires do these get tied into for the rears?and do you need one per bulb?or per circuit?
Old May 14, 2014 | 02:57 PM
NITRO UK's Avatar
NITRO UK
Hi
Bear with me cos I'm in the uk (euro zone lol) .
I wanted to have usa spec rear led lamps , i had to use resistors on my led lamps i got from ebay usa.
One resistor for each bulb / lamp .
These just connect into the + wire that would have gone to the stock bulb. I don't think it matters which way round the resistor goes .
Just cut the wire and connect the resistor onto those two ends .
Mine was slightly more involved cos my car had the euro harness which has separate bulb sockets for stop and tail , and indicators .
Will get the proper set up at some point , just didn't know of any alternative at the time .
Am i right in saying you have three wires going to each lamp .
two color and one black.
I can find out what color the brake / indicator + wire should be if that helps , think it might be green on one side and yellow on the other but can check .
Old May 14, 2014 | 03:14 PM
FLZapped's Avatar
FLZapped
The only LEDs I have are the reverse lights - and those don't require anything special.
Old May 14, 2014 | 06:24 PM
lionelhutz's Avatar
lionelhutz
The signal wires are likely yellow or green depending on the side.
You'll still likely end up replacing them after they fail and you've already cut-up your harness and damaged the insulation on the wire so moisture gets into the copper and corrodes it. There are lots of people saying they have failures. It's because those metal resistors are rated mounted to a heatsink, not in free air yet the suppliers don't say anything and people just mount them in free air and then they overheat and fail.
Old May 14, 2014 | 07:15 PM
Chicago1's Avatar
Chicago1
buy the harness don't hack the thin wiring to put in some 2 dollar resistors.
To Does this sound correct?
