B0017 Code....
Old May 16, 2014 | 07:06 PM
Delaware-C5's Avatar
Delaware-C5
Cruising
Default B0017 Code....
Help please...
I turn on my passanger airbag switch in the glove box and the airbag light stays on all the time.
What should I check?
Thanks for your input!
Old May 17, 2014 | 08:35 AM
dadaroo's Avatar
dadaroo
I looked at the FSM. Without the SIR load test tool and a Tech II about the only thing you can do is to check the wiring and connectors. There is no info as to measuring resistances or voltages in the diagnostics. Your code indicates some circuit issue causing a resistance or voltage deviation.
If some one has some actual experience in diagnostics I hope they can provide some more practical approaches.
