Steering rack question?
Old May 17, 2014 | 08:25 PM
smask04c5's Avatar
smask04c5
Default Steering rack question?
Can you loosely bolt the steering rack to the cradle and install assembly together? I am by myself and attempting to get it under the car tonight. Thanks
Old May 17, 2014 | 09:11 PM
lionelhutz's Avatar
lionelhutz
I can't think of any reason you couldn't. The factory puts it together by lowering the body over the assembled cradles.
Old May 17, 2014 | 10:07 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Make sure it's centered along with the steering wheel. Otherwise you be replacing the clock spring.
Old May 17, 2014 | 10:36 PM
smask04c5's Avatar
smask04c5
I've got that locked down; I took the engine out through the bottom after the cradle was removed. Halfway through the process, I decided that the cradle was much easier to remove then try to take out through the top.
I pushed the new engine on a pallet pull sheet and used the cherry picker; raised it just high enough to get the engine jack under it. Had to take off the intake to get grounds and EGR on cylinder heads. Ended up buying a map extension and drilling the front map mount on the 102.
To Steering rack question?
