Rear Shock Installation question
Old May 19, 2014 | 05:56 PM
flynhi's Avatar
flynhi
Default Rear Shock Installation question
Installing on a 99
I figured out how to compress the old shock to get it out but I need a DIY method to compress the new shock so that it is short enough to install.
any help appreciated.
Tks
Old May 19, 2014 | 06:24 PM
b_rad!'s Avatar
b_rad!
Try this link, they call this the Zip tie method.
http://fuzzydiceracing.com/test.htm
Old May 19, 2014 | 06:47 PM
guido7834's Avatar
guido7834
I don't recall having to compress the rears when I did mine. And it doesn't show it being done in the McRat method, which I used to help me through mine.
Old May 19, 2014 | 07:30 PM
flynhi's Avatar
flynhi
I'm using McRat also but I cannot get the replacement in without compressing it.
Old May 19, 2014 | 07:38 PM
KoreaJon's Avatar
KoreaJon
Originally Posted by flynhi
Installing on a 99
Tks
You'll definitely have to compress them to get them out....I used some heavy nylon cord. I put a loop at one end, and put the other end of the cord through the loop, and cinched it tight. Used a bow knot to tie it off. Too simple...
FWIW, I tried zip-ties....they kept snapping at JUST the wrong moment...
IHTH,
KoreaJon
Old May 19, 2014 | 09:33 PM
flynhi's Avatar
flynhi
Default Help?
Still hoping for some help on how to compress a replacement rear shock with DIY tools so that I can install it.
Gotta get my DD going tonight....
Tks
W
Old May 19, 2014 | 09:54 PM
dmarkshark's Avatar
dmarkshark
Be creative, you need to compress it first, your choice, zip tie or whatever,? I actually used guitar strings.
Oh, I also used a woodworkers clamp to compress it down, sorry, forgot that part.
Old May 19, 2014 | 10:00 PM
flynhi's Avatar
flynhi
I understand how to hold the compression but what I cannot figure out is how to compress the replacement shock with common garage tools.
Any ideas?
Old May 19, 2014 | 10:04 PM
KoreaJon's Avatar
KoreaJon
That ~sounds~ nice!
KoreaJon
Old May 19, 2014 | 10:18 PM
bighank's Avatar
bighank
Default Push the shock body while the rod is on a hard surface
Used the McRat method. Set up a pair of tiewraps to tighten after the shock was compressed. Pushed the body of the shock down with the rod on a hard surface like my driveway. After compressing the shock took the plastic end of the tiewrap and tightened around the shock and the rod. This worked for both the front and rear shocks. Not hard to do.
Old May 20, 2014 | 12:17 PM
lusor's Avatar
lusor
Only the front shocks need to be compressed.The rears slide right in.
Old May 20, 2014 | 12:45 PM
flynhi's Avatar
flynhi
Default Shocking Update
Perhaps it's my rookie technique but I had to compress both fronts and rears.
I figured it out differently.
Fronts - disconnect the tie rod and the lower A arm will drop enough to slide in a fully extended shock.
Rears -raised rotor. inserted rear spring bolt through the yoke on the shock and into the bolt hole in the lower A Arm. Stood shock upright with bolt/nut end on the garage floor. Then lower the rotor slowly to compress shock and tie it in compressed condition and install.
Thanks to all for inputs.
Old May 20, 2014 | 05:12 PM
guido7834's Avatar
guido7834
I gotta say I agree. I know I didn't zip tie the rears. Might just have to do some wiggling to get them in.
Old May 20, 2014 | 11:45 PM
Smokin Joe's Avatar
Smokin Joe
IHTH,
KoreaJon
exactly what I did.
Old May 21, 2014 | 06:47 AM
rjwz28's Avatar
rjwz28
I'm going to have to do this for the fronts, but the rears will be a cakewalk: my whole rear crossmember is on the ground underneath the car
Old May 21, 2014 | 09:42 AM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Do a google search for Froggy on YouTube. He has some great videos, one of which is replacing both fronts and rears. You can subscribe to his videos for free. Zuti
To Rear Shock Installation question
