ABS is not modulating; No Warning Lights or DIC codes
Old May 20, 2014 | 09:42 AM
SteveGreer's Avatar
SteveGreer
Cruising
Default ABS is not modulating; No Warning Lights or DIC codes
I took my 2003 Z06 that I bought about a year ago to my first HPDE this weekend and we did an all stop test to practice and my wheels locked up. I have no warning lights and no DIC codes. I looked at the fuses and 52 and 53 were both fine and all the way in. I can't find anything in the forum that matches this problem. I need help on where to trouble shoot. Thanks. By the way. The weekend was awesome.
Old May 20, 2014 | 11:25 AM
dadaroo's Avatar
dadaroo
Wondering if the pump motor has failed or the connection came loose. If I recall the pump has a separate 2 pin connector just for it. Not at home with the FSM to see if that would throw a code.
Indeed, your issue is very unusual.
Old May 20, 2014 | 01:53 PM
SteveGreer's Avatar
SteveGreer
Cruising
Where is the pump motor?
Old May 20, 2014 | 02:23 PM
3boystoys's Avatar
3boystoys
Can't believe you would have NO ABS codes if you had no abs on a panic stop.
Old May 20, 2014 | 02:39 PM
RedRiderZR1's Avatar
RedRiderZR1
It's in front of the motor. I too am surprised no codes. But then again.. count yourself lucky. My EBCM went out and it lit the IPC up with codes and lights.
Old May 20, 2014 | 02:48 PM
3boystoys's Avatar
3boystoys
Get out in the rain and do some panic stops that get the car to skid and see what happens. In a parking lot by the way!!
Old May 20, 2014 | 02:57 PM
RedRiderZR1
Good way to check. Also if you can, when you do that you should see ABS Active displayed on your DIC.
Old May 20, 2014 | 05:14 PM
SteveGreer's Avatar
SteveGreer
Cruising
I'll try the parking lot in the rain next time I have a chance.
The Traction control and AH seemed to work fine out on the track, got some AH messages. And I can turn them both off and also go into Competitive mode. The traction handling message comes on if I accelerate and spin the tires so that system seems to be working fine.
But believe it, I have no ABS with no codes in the DIC and none on the Instrument panel. And all the lights on the panel check during ignition turn on.
I guess I'll have to take it to the shop since this is an unheard of problem.
Thanks again.
Old May 21, 2014 | 12:12 PM
Rookieracer's Avatar
Rookieracer
Hmmm, I'm not sure I would rush to have that fixed if it were mine.
Old May 21, 2014 | 01:40 PM
3boystoys's Avatar
3boystoys
Why? ABS has saved my butt a few times in a few different vehicles.
Old May 22, 2014 | 12:17 AM
Rookieracer
With stickier tires and better brakes the ABS triggers too quickly.
ABS is a fantastic device for 90% of the drivers on the road.
I have a little different feel for what the car is doing than most drivers, I prefer to modulate the pedal based on the situtation/conditions and not some pre determined deceleration parameter.
Old May 22, 2014 | 06:36 AM
dadaroo's Avatar
dadaroo
Plus, ABS stopping distance can be longer than what a competent driver can do. ABS was really meant to keep poor drivers from loosing control.
Old May 22, 2014 | 08:04 AM
3boystoys's Avatar
3boystoys
It's to allow you to steer in a skid, the tech came from airplanes.
Old Oct 15, 2014 | 07:39 AM
SteveGreer's Avatar
SteveGreer
Cruising
Finally had England Green look at the ABS problem.
Here is the report.
Diagnose ABS system not working. Static tested
ABS module, circuits and system, ABS system
functioning correctly while static. Drove vehicle,
noticed ABS not functioning and one wheel
locking up, no pedal modulation. No outward
signs or codes to point to problem. Drove
vehicle extensively with GM Tech II diagnostics
tool. Initially suspected wheel speed sensors but
they passed all tests. Drove vehicle in small
circles and observed that the wheel speed
sensors were reporting incorrect data. Wheel
speed sensor harness was wired incorrectly -
left front for right front and vice versa.
Corrected wiring of wheel speed sensors.
Old Oct 15, 2014 | 11:07 AM
3boystoys's Avatar
3boystoys
How could the wiring be wrong?
Old Oct 15, 2014 | 02:48 PM
lionelhutz's Avatar
lionelhutz
Thanks for posting the findings. That is a rather unique failure.
Old Oct 15, 2014 | 08:36 PM
SteveGreer's Avatar
SteveGreer
Cruising
I suppose that a previous repair messed up the connections. I'm the second owner and I wasn't able to get any records from the previous owner since I got it from a dealer.
To ABS is not modulating; No Warning Lights or DIC codes
Old Oct 15, 2014 | 09:28 PM
4DRUSH's Avatar
4DRUSH
Very interesting find, but how did that affect your HPDE brake testing?
The test wasn't straight ahead brake testing?
Old Oct 15, 2014 | 09:34 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Have you tested it since the repair? I would think in a straight line panic stop, it wouldn't make a difference. If the sensors were crossed, the active handling should not have worked properly.
Just my .02
Old Oct 15, 2014 | 09:48 PM
SteveGreer's Avatar
SteveGreer
Cruising
The HPDE was a straight ahead panic stop where you were supposed to let the ABS bring you to a stop. I also had it happen on the track when I braked too hard. My wheels locked up and there was no ABS. I'm not sure why the crossed wires would cause this problem but must be something with the computer calculations. Garbage in Garbage out is my guess.
