High Oil Pressure
Old May 21, 2014 | 01:46 AM
schaffer C5's Avatar
schaffer C5
Default High Oil Pressure
I changed the oil about 4 weeks ago and starting yesterday my oil pressure is high
Idle 30PSI
Accelerating 55-65PSI
Constant speed 40PSI
I checked the oil and its at normal level and no leaks. Coolant level and color is normal.
2000 Corvette coupe with an A4 with 180,000 miles.
Old May 21, 2014 | 04:06 AM
C5Natie's Avatar
C5Natie
Those are good oil pressure numbers. What were they before?
Old May 21, 2014 | 09:01 AM
schaffer C5
Before they stayed right at 40PSI and the gauge did not fluctuate at all.
Old May 21, 2014 | 09:04 AM
schaffer C5
Originally Posted by 8VETTE7
Doesn't seem high to me but then I have no idea what the pressure was prior to the numbers you just posted or what your reference RPM's are....................
The RPM range is between 1500 to 3500 when accelerating.
constant speed is about 1900 RPM
Old May 21, 2014 | 10:06 AM
tgucc's Avatar
tgucc
Doesn't seem right. Pressure should change for different engine operating speeds (RPM's).
What you reported in your first post above is about normal Not sure what changed that caused the "more" correct numbers to be reported all of a sudden.
Engine temp will also change oil pressure. Pressure will drop when engine is warm.
Old May 21, 2014 | 11:17 AM
schaffer C5
Ok thanks guys. I thought something was wrong. I thought my oil pump might be going out or the oil pressure switch.
To High Oil Pressure
