Reversing Euro tails?
Old May 21, 2014 | 11:34 AM
mkiv808's Avatar
mkiv808
Default Reversing Euro tails?
The car I bought has Euro tail lights installed, with the harness.
How much of a pain is it going to be to do back to stock? Is it a plug-and-play installation or was cutting required?
Old May 21, 2014 | 01:35 PM
HERK's Avatar
HERK
There is a white wire under the dash that was cut. I know that has to be put back.
Old May 21, 2014 | 01:36 PM
NITRO UK's Avatar
NITRO UK
Hi
Probably be easier if you can get a stock harness ,which should just plug in .
You should find a white wire that has been cut coming off the brake light switch , just above the brake pedal .
If you do find that wire just join it back together .
It makes the rear flash ( indicator ) when turning and braking . usa spec.
That wouldn't be a good look with euro amber lights behaving like stop lights lol. so that's why it gets cut .
Should be able to get a stock harness / and rear lamps if you need those also of ebay.
Old May 21, 2014 | 04:06 PM
mkiv808's Avatar
mkiv808
OK great, so there's no cutting with the rear harness?
Old May 22, 2014 | 02:46 AM
NITRO UK's Avatar
NITRO UK
No bud should just plug in .
Connector should be just to the rear of passenger rear wheel on the frame.
Old Jun 23, 2014 | 08:47 PM
mkiv808's Avatar
mkiv808
Worried this is a hack job. Can anyone tell what's going on here?
Old Jun 23, 2014 | 08:53 PM
mkiv808's Avatar
mkiv808
More pics
Old Jun 23, 2014 | 08:54 PM
mkiv808's Avatar
mkiv808
More 2
Old Jun 23, 2014 | 08:55 PM
mkiv808's Avatar
mkiv808
More 3
mkiv808's Avatar
mkiv808
More 4
Old Jun 23, 2014 | 09:22 PM
mkiv808's Avatar
mkiv808
OK, I think I get it now. The Euro harness piggyback's onto the stock one? It looks like it's zip-tied to the stocker. My stock harness is still there, intact. So I just need to get underneath the car to unplug the aftermarket harness from the stock harness?
At least according to this: http://www.c5forum.com/diy/reareuro/
Old Jun 24, 2014 | 04:19 PM
NITRO UK's Avatar
NITRO UK
Hi mate
Not sure , maybe take the rear wheel off , if you then find a connector block unused then that should be the stock original .
Its not a bad job to remove the whole harness and then strip the tape to see whats been done to it. If you don't find any soldered wires I would think that harness is a GM euro EXPORT harness.
Bottom line just use the top bulb sockets and remove the amber sockets .
Or , and if your not sure just get a stock rear harness , plug in , join the white wire on brake pedal switch and your gtg .
If it helps I can buy that harness from you , might off set the cost of a usa spec one .
Thinking about it , you might be better off getting the usa spec harness , that way you can sell the euro lamps and harness as a plug in kit .
Old Jun 24, 2014 | 09:25 PM
mkiv808's Avatar
mkiv808
Originally Posted by NITRO UK
Hi mate
I figured it out. It's an additional harness that goes between the US male and female tail light harness connectors. It's plug and play. I just need to get the car up on a lift to remove the Euro harness, but other than that I successfully reversed it.
Reconnecting that white wire was a nightmare though! So tight.
NITRO, if you want the tail lights and harness - they are for sale. I have a lot of interest though.
Old Jun 25, 2014 | 02:34 AM
NITRO UK's Avatar
NITRO UK
Ah well done mate .
If you can sell the lamps and harness no prob , kinda thought it may help ya and I would have another option here in the uk , im running us spec lamps (red flashing indicators) , happy with them .
Hope you get a good price on them bud.
Heres some I made a few years back
Old Jun 25, 2014 | 07:44 AM
dadaroo's Avatar
dadaroo
For others reviewing this Thread, not all EURO conversions are plug and play. Many are cobbled up cheap conversions.
I just helped one member resolve a problem with one of these since he was having a problem with brake lights. The vendor had supplied cheap crimp thru the insulation connectors and the previous owner had actually used them.
It was not hard to tell him where to look to find the issue. He tracked the wire I told him to trace and the crap connection was hidden where it connected at the 3rd brake light. He had been struggling for I don't know how long trying to figure out what was wrong.
Also, I am amazed with even the Plug and Play conversions being sold they tell you to cut the White wire. They should also tell you how simple it is to just remove the White wire pin from the connector.
Old Jun 29, 2014 | 09:52 PM
mkiv808's Avatar
mkiv808
Agreed. It was a bear reconnecting it in that tight space, and not much room for error when stripping and crimping as the wire is pretty tight and not a lot of slack.
Old Jun 30, 2014 | 07:57 AM
dadaroo's Avatar
dadaroo
I think inserting a short piece of wire to bridge the gap would make it easier. A little solder and 2 pieces of heat shrink.
To Reversing Euro tails?
Old Jun 30, 2014 | 08:37 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Toque
Old Jun 30, 2014 | 09:36 AM
mkiv808's Avatar
mkiv808
Me in that tight space with solder is truly a terrifying proposition.
Old Jun 30, 2014 | 10:07 AM
dadaroo's Avatar
dadaroo
I know, I was repairing some wiring in one of my cars years ago when I could actually lay down on my back and do stuff. Was under the dash and soldering some things directly above my head. I just used safety glasses to protect my eyes and was waiting for molten solder to transform my face or burn my beard. Got lucky that day though.
