How to correct headlight gear alignment
Old May 22, 2014 | 06:57 PM
Jrichardevans's Avatar
Jrichardevans
1st Gear
Default How to correct headlight gear alignment
I replaced my rt headlight gear and now the light wont go all the way up. How can I correct this problem? I would greatly appreciate some help....
Old May 22, 2014 | 09:47 PM
lionelhutz's Avatar
lionelhutz
The motor itself has no stops and can turn full circles. The arm attached to the motor hits stops at the travel limits when the headlight is up or down, so see if you installed that arm wrong. Try moving it by the hand adjuster and watching the arm.
Old May 23, 2014 | 06:16 AM
Cybermind's Avatar
Cybermind
Also, make sure your bump stops are there, not damaged and properly inserted. There should be a total of four. One for the closed setting, one for the open setting and two at the rear of the headlight assembly to give it stability when open.
To How to correct headlight gear alignment
