How to change Transmision Fluid
I have a C5 03 corvette and cannot find instruction on how to change transmission fluid and repair possible leak. If anyone has the how to's, or what to do's on these,,,,,,,,,,,, or just one please send to me. I need it desperately. A long story, but as of right now car not drivable. I messed up and it got repoed, I got it back from bank, but need to get it home about 40mi. I would be very grateful if someone could help me out, i don't really have money to buy shop manual just need chapter 7. HELP!!!
You unscrew the plug on the bottom, and let it drain. Then you fill the fluid on the side where there is another plug. NOT the temp sensor plug. You will need a 10$ pump from autozone to pump in the fluid. Add until it starts to leak out. Have the car level and flat
