Are you trying to replace the bulb or the whole assembly?
Raise the headlights and remove the 3 screws holding the bezel. You should be able to reach in an pull the connector off. Twist the bulb counter-clockwise to remove it. If you need to replace the whole assembly, use a 10mm socket wrench and remove the bolt holding the lamp. Reverse the procedure to re-install.
