C5Z abs code 1214
Old May 27, 2014 | 07:42 AM
555ss's Avatar
555ss
Default C5Z abs code 1214
I got this code in My gf's 02 Z06 the manual say's replace unit.. I remember reading that some one rebuilds these things????
Thanks for any help
Old May 27, 2014 | 08:49 AM
Chicago1's Avatar
Chicago1
You should really use the search function it's a very helpful tool. This has been beaten to death but here you go..
http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old May 27, 2014 | 01:01 PM
StingrayRebel's Avatar
StingrayRebel
there is a huge thread literally posts down from yours on this very same page... I just got this code last week and successfully repaired the ebcm over the weekend to get rid of the code... a novice could do this repair so save some money and do it yourself
Old May 27, 2014 | 03:08 PM
Lt. Dan M.'s Avatar
Lt. Dan M.
I fixed my EBCM in my 02Z a while back via help of a thread on the forum. Just removed it, (very easy) opened it up, (not as easy as removing it ) and resoldered the relay. The solder joints didn't look bad and I didn't expect it to work but it has been fine ever since Good luck
Old May 28, 2014 | 06:41 AM
555ss's Avatar
555ss
Thank You guys. The search function never seams to work well for me but this time I did not even try so I'm sorry .
Old May 28, 2014 | 07:41 AM
dadaroo's Avatar
dadaroo
Forget using the Forum search. If I want to find something I know is in the Forum I Goggle using C5 Corvette Forum and then add whatever issue I think it was titled.
To C5Z abs code 1214
