Brake flush
Old Jul 22, 2002 | 03:01 AM
PaulJ's Avatar
PaulJ
Default Brake flush
What's the best way to flush the brake lines? The fluid in the reservoir looks kinda dirty (50k miles). Should I just keep pouring more brake fluid in while I bleed the lines? I've heard that using mineral oil is better. Should I do anything special to the ABS?
Paul
[Modified by PaulJ, 11:27 PM 7/21/2002]
Old Jul 22, 2002 | 08:26 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Brake flush (PaulJ)
never heard about the mineral oil but I just flushed mine with new brake fluid :cheers:
Old Jul 22, 2002 | 11:01 AM
gmblack3's Avatar
gmblack3
The best way to flush your brake system is to take it to the dealer. They can activate the ABS during the flush using the tech II. This will get all of the old dluid out for sure. Some have said that it will cost from $100 to $180
What I did was remove all the old fluid out of the reservoir using a turkey baster. Pour new fluid in and bleed each wheels till I got fresh fluid out. What year is your vette? The GM recommended order for bleeding the calipers differs depending on the year of your car. The 98-2000 cars should go RR, LR, RF, LF. The 2001-2002 cars should be RR, LF, LR, RF.
Also speedbleeders will help alot. http://www.speedbleeder.com You can do a 1 man bleed with these.
I have never heard of using mineral oil and will not do so. If you just drive on the street, get some valvoline syntec for $5 a quart. One quart should be enough to flush the system.
Here is the procedure for a 01-02 vette:
Steps 1-3 are for bleeding the master cylinder.
4. Fill the brake master cylinder reservoir with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. Ensure that the brake master cylinder reservoir remains at least half-full during this bleeding procedure. Add fluid as needed to maintain the proper level. Clean the outside of the reservoir on and around the reservoir cap prior to removing the cap and diaphragm, when cap removal is necessary.
5. Install a proper box-end wrench onto the RIGHT REAR wheel hydraulic circuit bleeder valve, then install a transparent hose over the end of the bleeder valve.
6. Submerge the open end of the transparent hose into a transparent container partially filled with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
7. Have an assistant slowly depress the brake pedal fully and maintain pedal position.
8. Loosen the bleeder valve to purge air from the wheel hydraulic circuit.
9. Tighten the bleeder valve, then have the assistant slowly release the brake pedal.
10. Wait 15 seconds, then repeat steps 7-9 until all air is purged from the same wheel hydraulic circuit.
11. With the right rear wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the right rear hydraulic circuit), install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
12. With the left front wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the left front hydraulic circuit), install a proper box-end wrench onto the LEFT REAR wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
13. With the left rear wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the left rear hydraulic circuit), install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
14. After completing the final wheel hydraulic circuit bleeding procedure, ensure that each of the 4 wheel hydraulic circuit bleeder valves are properly tightened.
15. Fill the brake master cylinder reservoir to the maximum-fill level with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
16. Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
17. If the brake pedal feels spongy, repeat the bleeding procedure again. If the brake pedal still feels spongy after repeating the bleeding procedure, perform the following steps:
Inspect the brake system for external leaks. Refer to Brake System External Leak Inspection .
Pressure bleed the hydraulic brake system in order to purge any air that may still be trapped in the system.
18. Turn the ignition key ON, with the engine OFF. Check to see if the brake system warning lamp remains illuminated.
19. If the brake system warning lamp remains illuminated, DO NOT allow the vehicle to be driven until it is diagnosed and repaired.
To Brake flush
