Lean codes after CAI install
Old May 28, 2014 | 03:34 PM
chasb4570's Avatar
chasb4570
Default Lean codes after CAI install
Just installed a Callaway Honker on my '04 six speed coupe. Only have driven around town a bit. The lean trim bank codes one and two, 171H and 174H have popped up several times. Is this possibly a normal circumstance until the computer relearns about getting more of the cool Phoenix air, only 102F right now. Or do I need to plan on having some diagnostic work done. Engine runs smooth not missing a beat and shows a considerable difference in the get up and go dept.
Thank you.
Chas
Old May 28, 2014 | 03:50 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Thank you.
Chas
Do you have any other work done to your car ?
Long Tube headers ?
Getting a tune from a tuner is a good idea if your car thinks its running lean.
A tuner can dial in your Air-Fuel ratio to where it should be for engine safety and maximum power output too.
Toque
Old May 28, 2014 | 03:55 PM
chasb4570's Avatar
chasb4570
Long Tube headers ?
Toque
Car is bone stock except for a TI exhaust.
Old May 28, 2014 | 04:16 PM
Dcollins3208's Avatar
Dcollins3208
Check to make sure all the clamps are tight between the MAF and TB
Old May 28, 2014 | 04:17 PM
Toque's Avatar
Toque
Sounds like that Honker is pulling a lot of air.
If I were you I would contact a tuner to have them check out the codes, and maybe even have them tune to set your Air-Fuel ratio's.
Toque
Old May 28, 2014 | 04:18 PM
Toque's Avatar
Toque
Good point !
Toque
To Lean codes after CAI install
