Can I just unplug the Traction Control sensors in the rear and not have it function? Its annoying how it still causes the car to bog down and not do a burn out even when it says its off sometimes. It happened once in a while at the strip. Or will it make it stay on or something? I know I will have to hit reset for it, but I already hit reset for not having TPMS so I dont care. I Just want traction control to stay off "always". Its only a drag car now.
Thoughts?
(I Meant to put TC in the subject line) TCC is torque converter clutch
Well Ill see if they are easy to reach under and unclip. Then Ill just do it at the strip. I drive about 35 miles each way to the track on southern cali freeways. The ABS has saved my *** from ramming into idiots swerving from a stopped lane into my 75mph flowing lane a few times. Id hate to loose it.
It sure seems easier to just pull the fuses since either way will disable ABS.
There are 2 fuses in the engine fuse box to pull. They should be Fuse 5 and 52. Verify for your car that they are the same fuses. Mine is a 2001.
They should not affect anything else unless you have RTD and then pulling Fuse 5 should have an affect on that. Don't think you need RTD at the drag strip.
