2002 signals don't work
Old Jun 1, 2014 | 07:26 PM
mikebg's Avatar
mikebg
1st Gear
Default 2002 signals don't work
I have a 2002 conv, the cig lighter casing was loose so I tightened it and then the turn signals would not work, I loosened and sure enough the signals worked, any ideas for a fix. Thanks from a new member.
Old Jun 1, 2014 | 08:19 PM
65GGvert's Avatar
65GGvert
No relationship. Try it again a couple of times and see if it wasn't a coincidence. Next time your signals don't work, press the hazard button off/on rapidly several times, then turn it off and see if your turn signals don't start working, at least for a little while.
Old Jun 2, 2014 | 07:08 AM
rubocop's Avatar
rubocop
Cruising
I had the same issue here. As stated, turn the flashers on and off and they should work. I turn them on for three flashes and then off. I do this 50 times. It frees up the relay and should last quite a while.
To 2002 signals don't work
