High volume tranny pan
Old Jul 22, 2002 | 04:09 PM
Steve02C5's Avatar
Steve02C5
From: Renaissance Festival TAZ the Wolfdog (R.I.P.)
Default High volume tranny pan
Can anyone recommend a high vol. tranny pan, either factory or aftermarket, which fits well and has adequate clearances?
Old Jul 22, 2002 | 10:02 PM
MRWHOOPPEE's Avatar
MRWHOOPPEE
Default Re: High volume tranny pan (Steve02C5)
they all end up going way too low
Old Jul 23, 2002 | 05:17 AM
Steve02C5's Avatar
Steve02C5
Default Re: High volume tranny pan (MRWHOOPPEE)
Bummer, but thanks for the info.
Old Jul 23, 2002 | 07:48 AM
Bill Reid's Avatar
Bill Reid
Considering the C5's A4 has no dip stick its fill/drain plug is mounted on the side of the pan... wouldn't think a standard aftermarket pan would be compatible. I have a cast aluminum (with cooling fins) Hughes aftermarket 4L60E pan on my 98 Z71, and although larger than the already standard deep pan, it only has provisions for a central drain plug located on the bottom of the pan. I would think the proximity of the drain/fill plug would be important if considering modifying any pan to fit... even if clearances are not an issue.
Old Jul 23, 2002 | 12:08 PM
carpe dm's Avatar
carpe dm
Steve: I suspect that out there "Somewhere in Texas" you run into some pretty good heat, just like we do here in AZ. I thought about the pan too, but am going with a B&M cooler. :yesnod:
Old Jul 23, 2002 | 09:20 PM
Steve02C5's Avatar
Steve02C5
Default Re: High volume tranny pan (carpe dm)
I have the B&M cooler p/n 70255 (13-16K GVW) and still run upwards of 195 F on hi 90-100F days. Would like to run max. 175 F, maybe a larger cooler.
To High volume tranny pan
