where to wire boost gauge light.
Old Jun 6, 2014 | 12:15 PM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
Default where to wire boost gauge light.
Im looking to wire my boost gauge light so that it comes on with the parking lights. I would also like to wire it in so that it will dim with the dash lights. I dont have any wiring diagrams so can someone tell me which wire to use and where it is located? Thanks!
Old Jun 6, 2014 | 03:00 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
You can pinch into one of the wires that goes to the fog light/trunk release switches.
It's easy to get to I think it's the blue one,
It goes on and off with the park lights but doesn't dim.
You can run a dimmer under the dash and set it to your preference.
I was going to tap into the cluster but that was a lot more work.
Old Jun 6, 2014 | 04:11 PM
Mallett Z's Avatar
Mallett Z
I just gotta figure out which wire coming off the factory dimmer **** is the one I want to tap into. Im not sure if that comes on/off with parking lights though.
Old Oct 3, 2014 | 03:52 PM
Gaspo's Avatar
Gaspo
ever figure this out? i'm looking to do the exact same thing
Old Oct 3, 2014 | 11:05 PM
ascastil's Avatar
ascastil
I used an add a circuit from autozone and just put it in the fog light fuse slot. Didnt run a dimmer though so I cant help with that.
Old Oct 4, 2014 | 11:26 AM
randyfl's Avatar
randyfl
I used the HVAC circuit. Not sure if the dimmer will work without some additional resistor. If you gauge is not LED you may some other issues.
To where to wire boost gauge light.
