c4c5specialist or C5-TECH please look here.
Old Jul 22, 2002 | 09:28 PM
SAXN8R's Avatar
SAXN8R
Default c4c5specialist or C5-TECH please look here.
I am trying to figure out if this is possible or not and whether it will break the bank.
http://forums.corvetteforum.com/zerothread?id=347715
Thanks in advance gentlemen! :seeya
Old Jul 22, 2002 | 09:45 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: c4c5specialist or C5-TECH please look here. (SAXN8R)
How big is the bank??? :D If you could make it work (dont know if it can be done) you would be looking at getting a different cluster,tire sensors,and the corosponding low tire module (part of keyless module)...Also issues with tire sensors mounting to stock Z06 wheels because they are machined for basic valve stems...
Old Jul 22, 2002 | 10:00 PM
SAXN8R's Avatar
SAXN8R
Default Re: c4c5specialist or C5-TECH please look here. (C-5 TECH)
Wow, don't know if the bank is big enough! Why do I need a new guage cluster? Isn't the actual display of the DIC the same? I would say anywhere below about 300 dollars wouldn't break the bank too bad. Thanks for the reply though!
Old Jul 22, 2002 | 10:35 PM
Wilson6t7's Avatar
Wilson6t7
i will boost this up for ya sax...
Old Jul 22, 2002 | 10:41 PM
SAXN8R's Avatar
SAXN8R
Default Re: c4c5specialist or C5-TECH please look here. (Micky T)
Thanks Micky T
Old Jul 22, 2002 | 11:12 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
" Why do I need a new guage cluster?"
Because I would be willing to bet that if you put a Z06 cluster in a C5,the tire pressure read out would not display on the DIC...The cluster is its own little module,and more than likely not set up for the low tire warning system ...
Old Jul 22, 2002 | 11:17 PM
SAXN8R's Avatar
SAXN8R
I see, thank you. I guess I will either have to settle for an aftermarket system, cough up some serious dough, or just guess my tire pressure when I am in motion. :lol:
To c4c5specialist or C5-TECH please look here.
