C5 Magnetic Suspension Noise/Longevity
Old Jun 9, 2014 | 11:02 AM
RED99CPE's Avatar
RED99CPE
Default C5 Magnetic Suspension Noise/Longevity
I have a 2003 Aniv Coupe with 22,000 miles and a while back have changed the sway bars for Z06 ones.
Although the car runs and handles great, especially with new Michelin tires, it has what I'll describe as a slight combination squeak/rattle that just audible at low speeds over slightly rough pavement.
I have been under it and can't find anything loose or leaking but was wondering about the longevity or life in time of the shocks
Any help will be appreciated
Old Jun 12, 2014 | 12:05 PM
RED99CPE's Avatar
RED99CPE
Originally Posted by 8VETTE7
I would start with the sway bar bushings, especially if you got the poly ones. I wrapped the bar with teflon plumbing tape directly under the bushings (front and rear) and my noises are gone, at least for now....... I also have the F55 magnetic system until the shocks start to leak and then it's gone.
Thanks that sounds like a really good fix I'll do just that.
