Trouble Code Help
Old Jul 23, 2002 | 12:16 AM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Trouble Code Help
Can anyone help and explain code to me. Iam showing a code P1416 which I find to be Air System Bank 2-B. What does this mean? Its in History and is now current and staying there until I take it for service next Monday?
Wayne 2001 Z06
Old Jul 23, 2002 | 01:46 AM
NJVetteGuy's Avatar
NJVetteGuy
Default Re: Trouble Code Help (Z06Corvette)
If I remember right, the check valve is the most probable cause of this code. It's a warranty issue so don't sweat it.
Old Jul 23, 2002 | 08:25 AM
THRAP 42's Avatar
THRAP 42
Z06,
The Air System Bank 2-B is;
An AIR pump is used on this vehicle in order to lower the tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
So it looks like you have an inoperative bank.
later,
Old Jul 23, 2002 | 03:44 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Default Re: Trouble Code Help (NJVetteGuy)
Thanks for setting me straight. I thought this was the case but no manual to verify. Scheduled for service next Monday. :seeya
To Trouble Code Help
