Silver electrode core spark plugs
They are made, or sold, by a company I've never heard of and are a non resistor type. The brand is Nology and the store that sells them, perhaps Nology as well, makes three basic claims about the physical properties of Silver that makes using it advantageous in spark plugs. The first two I am not sure about and will have to look up when I get a chance (I'm a Chemistry teacher). They claim silver to be have the best electrical and thermal conductivity of any metal. Now the third claim is absolutely true and that is that silver is at least one of the two most non-reactive metals along with gold. Silver however, is not as soft as gold. My question is, these plugs are on sale but still expensive. $12.00 a piece . Are they worth it.
http://forum.roadfly.com/threads/121...um-Spark-Plugs
I'll let you search into resistor versus non resistor plugs. Non resistor plugs can cause radio interference in some cases. Not sure if it would in a C5 stock radio versus aftermarket radio.
You are trying to improve a computer controlled event in exactly what way, you didn't say. Changing the material in the electrode? If that is the idea, one must assume there was a mistake in the original engineering and subsequent update of the recommended spark plug.
Probably not,, I don't know, but at least one can say nothing from the factory ever specified a silver type of electrode. If you consider a stock plug, the material in the electrode is chosen for service life, conductivity is not a problem, each plug has its own coil and spark event, for pete's sake.
If you want to play around with plugs, you need an engine from the past.
This engine has a plug specification not a plug speculation. You start screwing around outside of the engines intended design performance with random decisions and you might cause a cascade of trouble down the road. This is computer designed highly engineered stuff, any machine operator will tell you to follow the directions in the owners instructions, first , last and always.
Besides circuits can be funny. not funny good, either
So I'm basically MODIFYING my 2001 LS1 engine into a 2002+ LS6 clone that should breath better than stock. I have LS6 heads to port, an LS6 like cam, and upgrades to the intake and exhaust, but its all naturally asperated. My short list of plugs include NGK TR5s or TR5IX. please advise!
Sent from my SCH-I415 using IB AutoGroup
