Charging system Failure Message
Old Jun 16, 2014 | 10:24 AM
joewom's Avatar
joewom
Default Charging system Failure Message
Ok this morning got in to go to work and started up the vette. I almost missed the message but it flashed on the screen and went away. I didn't clear it or anything. Voltage was 14.2 and all seemed fine. Looked at the codes and no codes other then the two that are always present. PCM one that is there from the Tune and the TPS one from traction control. No issues starting or anything and like I said I almost missed the message I just happened to glance at the DIC.
Old Jun 16, 2014 | 11:15 AM
dadaroo's Avatar
dadaroo
Hopefully just a glitch. If it happened early on during starting like you describe that could be the explanation. Have you done anything lately (~ 6months) that might affect the charging system? Let us know if it happens again. Could be a loose connection or a bad lug.
Not at home with the FSM and other info to verify if that message should have an associated code.
Old Jun 16, 2014 | 11:55 AM
joewom's Avatar
joewom
I only owned it for a month. New battery 3 weeks ago. We did rewire the electrical water pump as that was why I was overheating as the wiring and relays were really bad. That was 3 weeks ago also. Nothing else though. It road fine to work. I will see about to go to lunch and see if it shows again.
Old Jun 16, 2014 | 01:50 PM
3boystoys's Avatar
3boystoys
I get this once or twice a year, never been an issue.
Old Jun 16, 2014 | 02:16 PM
joewom's Avatar
joewom
Thanks, Good to know. I will check all connections but I started it for lunch and started right up no message.
Old Jun 16, 2014 | 03:30 PM
3boystoys's Avatar
3boystoys
There is a test the system runs at startup on the electrical system, it will show this on occasion with no real problem.
Old Jun 16, 2014 | 07:39 PM
joewom's Avatar
joewom
Originally Posted by 8VETTE7
I know you have not owned the car long enough but if you see the message a few times each year, forget about it. If you see it every other time you start the car then you have an issue that needs to be addressed.
Thanks. Started it 4 times after and nothing. Will keep an eye on it hopefully it's nothing!!
Old Jun 16, 2014 | 09:13 PM
IH8FORD's Avatar
IH8FORD
I just bought mine a month ago and have had that happen once but has been fine ever since. I've put about 2500 miles on since it happened.
Old Jun 18, 2014 | 12:51 PM
GeneT's Avatar
GeneT
I get the "charge system fault" message if I don't drive the car for a couple of weeks. Nothing to worry about if your battery is good.
To Charging system Failure Message
