Replacing AC Fill Valve
Old Jun 17, 2014 | 12:04 AM
Choreo's Avatar
Choreo
Default Replacing AC Fill Valve
Not sure that is the proper term, but I recently noticed my AC was not cooling for the first time in 14 years (at least not so much on the driver
s side), so I took the car to a shop and they said the refrigerant was low (20-lbs). They added a can of refrigerant and everything was back to normal, but they said the inlet valve (where they connected the AC recharge line) was leaking when they removed their equipment. It made it a couple weeks and now I am back to cool air vs cold.
What is involved in changing out the valve? Does that whole metal insulated line have to be replaced?
Old Jun 17, 2014 | 12:12 AM
Boss75's Avatar
Boss75
If it's just the valve all you have to do is have the A/C evacuated and then using a valve stem removal tool just unscrew the valve and replace it. They have a small rubber seal on them that will wear out over time. You can pick both items up at a parts store. I believe the tool is a slightly different size than a valve stem removal for a tire though. Then just recharge your A/C
Old Jun 17, 2014 | 12:15 AM
Choreo's Avatar
Choreo
Thanks... does not sound too bad then. Hopefully that is the only leak. Must be a really slow leak as it was fine for a couple weeks (and still not really warm).
Old Jun 17, 2014 | 01:31 AM
Smokin Joe's Avatar
Smokin Joe
When it's charged, put some water on the top of the valve and see if it bubbles indicating a leak.
The various O-rings go out on these things. Shoot a can of dye in there, recharge (so the compressor engages) and run the system. Use a UV light and the glasses and look around all the connection points.
If you have access to a sniffer run the AC and see if you can use that to determine the leak. (That's the best way, but you have to know someone with a shop that has it).
If you open the lines, minimum replace the applicable o-rings, dryer, and orifice tube. Pay attention to the oil in the dryer, because you will need to replace the same amount of oil in the new dryer.
To Replacing AC Fill Valve
