plugs
Old Jun 18, 2014 | 02:52 PM
True blue1914's Avatar
True blue1914
7th Gear
Default plugs
All 4 plugs on the passenger side black driver side what what is the correction I need to make . I don't have any cats and headers have been installed.
Old Jun 18, 2014 | 03:02 PM
NukeC5's Avatar
NukeC5
You're saying that the passenger side plugs are black due to richness and not the other side? Id suspect a leaking injector, but that's just a first thought.
Old Jun 18, 2014 | 03:37 PM
True blue1914
7th Gear
R u saying one injector will have all 4 plugs blk?
Old Jun 18, 2014 | 04:21 PM
Rj-lo's Avatar
Rj-lo
Im not even sure what the question is...
Old Jun 18, 2014 | 04:37 PM
bobby777's Avatar
bobby777
Say What? A black driver-not the correct driver-don't have cats-and you have headers?
Old Jun 18, 2014 | 05:08 PM
True blue1914
7th Gear
2005 corvette passenger side plugs are blk (rich) driver side is normal
Old Jun 19, 2014 | 06:04 PM
SG Lou's Avatar
SG Lou
This is C5 Tech......C6 Tech is around the corner !
All kidding aside, I'm thinking the same thing that NukeC5 mentioned.
Old Jun 21, 2014 | 06:23 PM
True blue1914
7th Gear
Ok iis got a exhaust off a 2009 corvette and someone said it may not be processing the air flow through the ecm
Old Jun 23, 2014 | 09:49 AM
3boystoys's Avatar
3boystoys
Since you do not have a C5 that you can get the codes from the dash, time to find a scanner and see if you have any codes dealing with rich or lean fuel on one side or the other. The O2 sensors will pick this up and you have codes.
Old Jun 24, 2014 | 01:20 PM
True blue1914
7th Gear
Could a bad or cause all four plugs to get black?
Old Jun 24, 2014 | 01:51 PM
3boystoys's Avatar
3boystoys
You need to work on your English, I have no clue what your even saying here.
Old Jun 24, 2014 | 10:00 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
I don't understand either. Skewed o2?
Old Jun 25, 2014 | 05:27 AM
dhowdy's Avatar
dhowdy
you're*
Old Jul 27, 2014 | 10:02 AM
True blue1914
7th Gear
Thanks for the help.
To plugs
