Water Gauge
Old Jun 21, 2014 | 07:40 PM
fearless one's Avatar
fearless one
Navigator
Default Water Gauge
I have a 2003 anni and am having a problem with the water gauge in the dash. It goes all the way to the red when I turn it on,the car runs fine and I haven't seen any codes in the dash. I have tried disconnecting the battery and this did not help. Any input would help.
Old Jun 21, 2014 | 09:09 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
The sender probably crapped out.
Old Jun 22, 2014 | 11:43 AM
fearless one
Navigator
Default sender unit
OK Thanks where is the sending unit? I see a small one on the driver side head by the manifold.
Old Jun 22, 2014 | 12:32 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Before replacing the engine coolant temperature sensor, check the water temp readout on the D.I.C. display.
If the temperature reading is close to the ambient outdoor temperature, with the engine cold and not running, it is not a bad ECT sensor causing your problem.
To Water Gauge
