idle high but intermittently
Old Jun 22, 2014 | 02:54 PM
ffastwheels's Avatar
ffastwheels
Default idle high but intermittently
When the car is warm it idles anywhere between 15 -1800 rpm and when i come to a stop 2-3 seconds later it goes back to normal....i already changed the MAF sensor..but i will assume there is an idle sensor..that could be defective...any help on this issue would be appreciated 2001 z06 with 25k ...thnx
Old Jun 22, 2014 | 07:39 PM
BKH's Avatar
BKH
Mine started pulling this trick recently.
Old Jun 22, 2014 | 08:05 PM
ffastwheels
Spoke to friend of mine he told me the car needs a throttle body reset and gm dealers do it and it takes 10 minutes.......ill try it and post the results at a later date.......
Old Jun 22, 2014 | 10:56 PM
BigGun's Avatar
BigGun
Never heard of such a thing.
Use the dic and see if you have any codes set.
Old Jun 22, 2014 | 11:00 PM
ffastwheels
No codes....the car runs great just doesn't go to its normal idle until the car is completely stopped for a couple of seconds...it's just annoying.....if it's not a throttle reset ...what the hell could it be?
Old Jun 22, 2014 | 11:17 PM
ffastwheels
Any advice would be greatly appreciated
Old Jun 23, 2014 | 05:20 AM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
take off tb and clean it
Old Jun 23, 2014 | 01:51 PM
rhyno's Avatar
rhyno
any mods done? any other service done recently?
i'd look for vacuum leaks around intake.
Old Jun 23, 2014 | 06:14 PM
ffastwheels
I will do both the throttle body ckean and check for vacuum leaks....thanks for the advice.....if it works....well...good for me if it doesnt ...dealer.....
Old Jun 23, 2014 | 06:15 PM
ffastwheels
Just a loudmouth exhaust wheels and brakes....no engine mods...
Old Jun 23, 2014 | 10:09 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Also, as previously mentioned, check for codes.
Old Jun 23, 2014 | 10:52 PM
ffastwheels
There r no codes... ill keep everyone posted on the progress if any....once again thnx
Old Jun 26, 2014 | 11:29 PM
ffastwheels
Cleaned tb no changes....same problem
Old Jun 26, 2014 | 11:39 PM
ffastwheels
No leaks and no service done ...bone stock.....so far changed Maf sensor , plugs and wires same problem...high Iidle and again today Maf sensor code with check engine light went on....did a reset....after that the car drove fine except for the high idle.....pis sing me off.....I guess I'll have to bring it to the dealer....it will be Murphy, s law the car will probably show no problems......we will see....have a good one
To idle high but intermittently
