Which Battery should you replace the stock one with?
Old Jul 23, 2002 | 09:17 PM
Xssesive's Avatar
Xssesive
Default Which Battery should you replace the stock one with?
Need to replace factory battery, which one do you guys recommend? :rolleyes:
Old Jul 23, 2002 | 09:57 PM
hhan's Avatar
hhan
Default Re: Which Battery should you replace the stock one with? (Xssesive)
If you wish to stay with Delco. the AGM which came out with the '01 is a big upgrade over the flooded,and no chance of leaks and much less self discharge. If you want to go specialty, the Optima seems the popular choice.
and that is also AGM. There are also some gel models, but they are much more expensive and need charging rate monitored closely as they are not supposed to go any higher than 14.10 volts
Old Jul 23, 2002 | 10:01 PM
Dale RED 98's Avatar
Dale RED 98
I went with the Optima Red Top. :cheers:
Old Jul 23, 2002 | 10:13 PM
luvinc5's Avatar
luvinc5
Default Re: Which Battery should you replace the stock one with? (Dale RED 98)
Old Jul 23, 2002 | 10:31 PM
99HT's Avatar
99HT
I went to Pep Boys and bought a Optima "Redtop" for $109.00. Be sure to get the smaller/cheaper Redtop. They have another Redtop model for $119.00 plus a Yellow top version, but they do not fit the battery tray as well.
Old Jul 24, 2002 | 07:01 AM
turboo2u's Avatar
turboo2u
Default Re: Which Battery should you replace the stock one with? (99HT)
Bought the Red Top from Pep Boys but it didn't fit and they didn't have the adapters. Went to Wal-Mart and picked up their MAXX 75. It came with a 3 year full replacement warranty and a 9 year pro-rated warranty. Has much more CA and CCA than the AC Delco unit, fits and looks better than the Optima and only costs $54!
Old Jul 24, 2002 | 06:24 PM
mbtc5vette's Avatar
mbtc5vette
Default Re: Which Battery should you replace the stock one with? (turboo2u)
:seeya
Old Jul 24, 2002 | 06:33 PM
I went with the Optima Red Top also. Got it from LAPD for $110. Looks and works great.
Old Jul 24, 2002 | 10:24 PM
Xssesive's Avatar
Xssesive
Default Re: Which Battery should you replace the stock one with? (JDs00PewterCoupe)
I think this battery has already been replaced, current one is 78-6YR. Is that the stock one for a 98? :confused:
Old Jul 25, 2002 | 02:27 AM
nassau99's Avatar
nassau99
not sure, but do yourself a favor and replace with optima!!!! you have apotential for in excess of $2000 for repairs if you have a acid leak in this area. just not the place to be cheap and try to save a few bucks-spend the $130 bucks-cheap insurance!! :smash: :smash: :smash:
To Which Battery should you replace the stock one with?
