powerbraking problem
Old Jun 24, 2014 | 09:34 PM
butcher00's Avatar
butcher00
2nd Gear
Default powerbraking problem
tried to powerbrake my 2000 c5 and at 1500 rpms car boged down and shook. any ideas why
Old Jun 24, 2014 | 09:41 PM
helga203's Avatar
helga203
auto or manual trans. If manual did you leave it in a low gear 5 or 6?
Old Jun 24, 2014 | 09:50 PM
butcher00's Avatar
butcher00
2nd Gear
automatic had it in drive would not go over 1500 rpms when holding brake. reves fine in park and takes off fine in drive when you hit the gas
Old Jun 24, 2014 | 10:23 PM
Anthraxmm's Avatar
Anthraxmm
stock torque converter is only around 1800 or so i think. put a 4000 in it and never look back
Old Jun 24, 2014 | 10:36 PM
rodsvet's Avatar
rodsvet
Did you turn off the active handling? Rod
Old Jun 25, 2014 | 08:10 PM
RonSSNova's Avatar
RonSSNova
Abuse mode as well as the traction control don't like you power braking.
Try it with the TC off
Old Jun 25, 2014 | 08:55 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Abuse mode in pcm cuts power at 1200 rpms by 50 percent. I have turned my traction control off and still does it. Been discussing it here https://www.corvetteforum.com/c5-scan-and-tune/3475707-please-help-cant-build-up-or-spin-tires-over-in-my-c5-corvette.html
Old Jun 26, 2014 | 12:16 PM
VinnyT's Avatar
VinnyT
Also torque management plays in part...
To powerbraking problem
