c5 alternator charging issues
Old Jun 25, 2014 | 10:09 PM
xtremeironworks's Avatar
xtremeironworks
Default c5 alternator charging issues
Hello All,
I just upgraded my 2004 LS1 engine with Port polished 243 heads, Lunati cam, long tube exhaust, Air Raid CAI, Stage 3 Transmission, and some small other items. Also had Professionally tuned/Dyno by Nic D (Excellent professional guy). I also had my water pump, valve covers, and alternator bracket powder coated. Here is the issue. I have to rev the RPM's about 4000 before the Alternator starts to charge around 13.3v (Which I think should be more than that). Also if i turn on any accessories it will read a lower voltage.Before I rev motor it is about 11.8v. I replace alternator and have new Optima Red top battery. I checked all ground locations they are all tight. Also these readings are from my DVM, not just from the display in car. I did research on internet and maybe starter connections, but I check all connections and they are tight. Any ideas would be helpfull,
Thank you in advance,
Jimmy
