Rear Sway Bar Bracket, Stripped?
Old Jun 26, 2014 | 02:09 PM
aTeam's Avatar
aTeam
Default Rear Sway Bar Bracket, Stripped?
I had a catback put on two weeks ago and I think the shop may have stripped the rear sway bar bracket bolt on the passenger side. It looks like this
It was fine prior to the shop removing and reinstalling it. When I try to tighten it now it gets close to flush then starts going backwards. Any suggestions on how to fix this?
Old Jun 26, 2014 | 03:05 PM
DIXZ's Avatar
DIXZ
Replace the bolt. It is just a multipurpose bolt that is easily replaced.
Have you removed the nut to see which threads are bad, the bolt or the nut?
Old Jun 26, 2014 | 03:17 PM
aTeam's Avatar
aTeam
That's what I just did. All fixed thanks
To Rear Sway Bar Bracket, Stripped?
